People's opinion (xbox related, no haters required)
  1. OW3N111
    Jelly Bean Sep 7, 2014
    OW3N111 , Sep 7, 2014 :
    So a decent 1TB hard drive I can put in my xbox one as I'll be out of space before end of November with the games coming out.
    I've herd all things like they die after so long (1 year) then you'll lose your data
    Hard drives that need their own power supply are better.. ?? (don't know how true that is) but I've seen other ppl in tech forums say even those have corrupted over time
    Basically I've never needed a hard drive before and im in unknown waters
    Any help from anyone that knows about these things or have bought a few hard drives themselves that would like to share their experiences please comment.
    Any links to specific good ones you've herd about or own also welcome =)
    Not looking to spend over £80/90
    I know game sell this one
    http://www.game.co.uk/en/m/adata-1t...=589111&pageNumber=2&sortBy=MOST_POPULAR_DESC
    oscarvanl likes this.
  2. teqnix
    Lollipop Sep 7, 2014
  3. DRCH
    Marshmallow Sep 7, 2014
  4. oscarvanl
    oscarvanl , Sep 7, 2014 :
    This is for game storage, no
    OW3N111 and teqnix like this.
  5. kopelence
    Gingerbread Sep 7, 2014
    kopelence , Sep 7, 2014 :
    I personally prefer PlayStation. Xbox really sums up at a bigger price when you add up batteries for the controller, Xbox live membership etc.. But thats none of my bussiness :)
  6. oscarvanl
    OP, the best thing is an internal replacement hard drive for your Xbone. Anything 2.5" should be alright. For an external drive, I'm not up to speed with the Xbone - If it does support external drives get one with a power supply, the xbox's USBs likely won't supply enough power and if they do it will put extra strain on the Xbox's power supply.
    I don't worry about this because I play on PC, my case supports 4 hard drives and drives without enclosures are dirt cheap. I currently have 1x1TB and 2x750GB.
    Hard drives don't generally break or go corrupt within a year as you said, I have hard drives over 7 years old that still work (but I don't use them as they will likely die soon)
    Hard drives are made from multiple spinning discs, dropping a hard drive or bashing it will kill it quickly.
    Remember, your Xbox 360 (if you had one) has an ordinary hard drive for storage, and that's probably still working.
    This is in your budget. I recommend this highly. http://www.amazon.co.uk/gp/aw/d/B00...200_QL40&qid=1410120577&sr=8-1#ref=mp_s_a_1_1
    OW3N111 likes this.
  7. skruf97
    Froyo Sep 7, 2014
    skruf97 , Sep 7, 2014 :
    That should work fine :) i have a 1tb hard drive in my ps3 sow it should work just fine om the xbox too :)
  8. skanda
    Froyo Sep 7, 2014
    skanda , Sep 7, 2014 :
    By the time it becomes corrupted Xbox onetwo.5 will be out.. I'm currently browsing a hard drive for my Xbox one as well
  9. TjRuben
    Honeycomb Sep 7, 2014
    TjRuben , Sep 7, 2014 :
    I got a PS4, simply because Xbone wasn't available in my country (Netherlands) but i have replaced the original sticks with Xbone sticks! I like them so much :D
  10. oscarvanl
    skanda likes this.
  11. SeriusNtentions
    Sep 7, 2014
  12. jaycob619
    jaycob619 , Sep 7, 2014 :
    Would be good if they did have something set up seeing as saps are paying just for the privilege to play online LOL
    I'd say just look about for a quality 1TB drive from a brand that doesn't have too many failure rates.
  13. skanda
    Froyo Sep 7, 2014
    Thank you!! This one actually looks really good.. I was think about
    http://www.amazon.co.uk/gp/aw/d/B00...10_SY165&qid=1410121050&sr=8-4#ref=mp_s_a_1_4
    But the one you sent looks good value for money and reliable.. I'll go for it.. much appreciated.
    OW3N111 and oscarvanl like this.
  14. oscarvanl
    They aren't magicians unless they have cloud processing which adds a massive delay and lag to everything...
  15. Milad
    Milad , Sep 7, 2014 :
    Buy an internal HDD?
    I can do that with my PS4 and PC but i don't know about Xbox.
  16. jaycob619
    You're gonna be using it to store stuff on it mainly for game management don't expect to play games right off the cloud without fees.
    They already have OneDrive and could have some good integration going on if they got creative.
  17. OW3N111
    Xbox did some crap to it so it can't be replaced =/
    Milad likes this.
  18. OW3N111
    Thanks for help but this has usb 3.0 an xbox is 2.0 it won't fit right?? Or they fit both?
  19. oscarvanl
    Usb 3 is backwards compatible meaning it will work on Usb 2 devices at USB 2 speeds. If you were to use it on a USB 3 device (Xbox Two?) then it would be faster. There are no negatives
    OW3N111 likes this.
  20. oscarvanl
    They already have cloud save storage, but saves are tiny.
