177
Performance Tips for the OnePlus 7 Pro
  1. G_Neeraj_Porwal_XSAR
    Honeycomb Jul 25, 2019
    G_Neeraj_Porwal_XSAR , Jul 25, 2019 :
    dear brother, it's a foult of apps developer it's not your device issue I think
    just wait for new version of app or just informed to that's application development . it's not device foult .
    never settle
  2. G_Neeraj_Porwal_XSAR
    i want to say that just update your all play store app okk keep device updated keep Oxygen version always updated . not needed to use extra mind .. because software team is seeing all ..our work is just keep up to date full device ..
    thanks
    never settle team of OnePlus.
    Texasaggie1 likes this.
  3. Ocelot1515
    Cupcake Jul 25, 2019
  4. G_Neeraj_Porwal_XSAR
    software Engineer is working for all users ...team is working for the days and nights 24× 7 only for OnePlus lover . stay connected
    thanks for choosing one plus
    never settle
    Texasaggie1 and Ocelot1515 like this.
  5. Ant91
    Gingerbread Jul 25, 2019
    Ant91 , Jul 25, 2019 :
    I get notifications for updating apps on play store days after it has been released. Do I have to clear the cache?
  6. G_Neeraj_Porwal_XSAR
    that's a different matter .you are asking different matter you can do it .. ( clear the cache)
    but remember do it carefully your one mistake can erase your all device deta so select only cache options.
    OnePlus
    never settle
  7. G_Neeraj_Porwal_XSAR
    Nikhilvinay
    After the new update the battery performance has decreased​
    just search a thread on community for better battery backup. tips for that and disable useless app's ok
  8. W1558899570048
    Cupcake Jul 26, 2019
  9. Nikhilvinay
    Nikhilvinay , Jul 26, 2019 :
    Hokk I vil try
  10. RAHUL.KAMBLE
  11. Jshreeravi
  12. F_ShrEyas_Naduvinmath_EC
    Eclair Jul 27, 2019
    Deactivated User likes this.
  13. Deactivated User
    Jul 27, 2019
  14. F_ShrEyas_Naduvinmath_EC
    Eclair Jul 27, 2019
    F_ShrEyas_Naduvinmath_EC , Jul 27, 2019 :
    i am regretting buying 7 pro i owned s10 plus before .. i still wish i had that phone man this phone has so many problems
  15. guganhos
    Cupcake Jul 28, 2019
    guganhos , Jul 28, 2019 :
    l kept at 0 level all. shall we keep it like that. it is very fast in this setting.
  16. Texasaggie1
    US Brand Ambassador Jul 28, 2019
    Texasaggie1 , Jul 28, 2019 :
    it is so fast like that! I like a little animation though
    guganhos likes this.
  17. guganhos
  18. Texasaggie1
    sometimes, when animation is off , there is a little circular arrow symbol that shows up while waiting. I don't like that. I use System UI tuner. Have you tried that?
    buntycubal and guganhos like this.
  19. Texasaggie1
    what problems other than the camera are you having?
    are you updated to the latest version of oos?
    buntycubal likes this.
  20. Texasaggie1
    I had it on the 6 but it went away after and update in OS. I never had it on the 6t or the 7 Pro.
    have you tried G cam on your 5T?
