177
Performance Tips for the OnePlus 7 Pro
  1. Texasaggie1
    US Brand Ambassador Jul 28, 2019
    Texasaggie1 , Jul 28, 2019 :
    try rebooting it and you also may want to try turning on battery saver. I use battery saver almost all the time now
    if you go into battery settings you can also see what app is burning up the battery.
    buntycubal and RAHUL.KAMBLE like this.
  2. Texasaggie1
    Two of the u.s. brand ambassadors wrote that article. its really helpful:
    https://forums.oneplus.com/threads/oxygenos-battery-saving-tips-for-the-oneplus-7-pro.1059856/
    also you might want to play around with battery saver mode. just for grins I started using it a couple of weeks ago and it turns out I really like it. I have it turn on automatically on my phone if my phone gets down to 30% but honestly I just leave it on most of the time now anyway LOL. it's insane amount of battery life that I get with it turned on.
    buntycubal likes this.
  3. Texasaggie1
    I definitely would. if you just clear the cache of the play store app, it shouldn't cause any issues and it just might fix the issue that you're having
  4. Texasaggie1
    currently on the OnePlus 7 Pro latest oos the version is 3.4.19.
    that apk may be from a beta rom or something like that
  5. Texasaggie1
    have you opened a bug report? it's super easy to do and the developers will get back with you and try to work through the issue with you.
    when you first open the community app on your phone go to the profile tab. Then click on profile then click on my feedback then click the plus button to open a new bug report
  6. Ant91
    Gingerbread Jul 28, 2019
    Texasaggie1 likes this.
  7. Texasaggie1
    open the community app on your phone, go to the profile tab, click on my feedback, then click the plus button to open a new bug report. it's super easy!
  8. Texasaggie1
    Ant91 likes this.
  9. Jshreeravi
    Cupcake Jul 28, 2019
    Jshreeravi , Jul 28, 2019 :
    I have done that
  10. Texasaggie1
    what problem are you having exactly?
  11. RAHUL.KAMBLE
    RAHUL.KAMBLE , Jul 28, 2019 :
    thank you Sir
  12. A1564320757388
  13. Texasaggie1
  14. Jshreeravi
  15. guganhos
    guganhos , Jul 28, 2019 :
    sir, how to use system UI tuner. I changed settings to .5 after your answer.
  16. Deactivated User
    Jul 28, 2019
  17. G_Neeraj_Porwal_XSAR
    Honeycomb Jul 28, 2019
    G_Neeraj_Porwal_XSAR , Jul 28, 2019 :
    Texasaggie1
    when you first open the community app on your phone go to the profile tab. Then click on profile then click on my feedback then click the plus button to open a new bug report​
    i agree...
  18. F_ShrEyas_Naduvinmath_EC
    Eclair Aug 1, 2019
    F_ShrEyas_Naduvinmath_EC , Aug 1, 2019 :
    yes i am not receiving any new update rolled out by one plus .. i always have to update it via 3rd party app .. y i s so happening?
  19. Aathif_Mahir
    Ice Cream Sandwich Aug 3, 2019
  20. Dharminder@0303
    Cupcake Aug 7, 2019
