Phone App. Search issue (dialer) via OnePlus 8T
  1. as_if_i_am
    Gingerbread Dec 29, 2020
    as_if_i_am , via OnePlus 8T , Dec 29, 2020 :
    Another major issue,
    Some people will definitely say that Phone app. is google app. but this issue was not available on 6T 😊
    Phone App. dialer from a long time have a feature to search with typing names directly on dialer via number.
    So if I want to search for ASIF i would type 2743 and it would search for all matches.
    This isn't working for many of the contacts in my phone unless i go to top search bar and search name via alphabets.
    All numbers are linked to google only.
    Check this issue and please fix at least one of the issue I'm facing.
    There are plenty of issues I've already reported.
    #oneplus8t #oneplus #dialer
    No results when I type via dialer numbers
    Pochinki likes this.
  2. LordPM
    LordPM , via OnePlus 8T , Dec 29, 2020 :
    Working on my end.
    I type numbers and get the related result.
    Even I tried saving a number on device, not on Google account.
    That too worked.
    Check your settings.
  3. psygarden
    OnePlus TV Product Ninja 2021 Dec 29, 2020
  4. Arun_R
  5. Pochinki
    Froyo Dec 29, 2020
    as_if_i_am likes this.
  6. as_if_i_am
    Why do you think I haven't checked my settings first 🤐
    I tried a lot of things then I created a thread over here
  7. as_if_i_am
    I already knew someone would say this thing 😂 whole android if of Google , then i should connect with google devs. all the time for any issues, right .
  8. A.Saketh Gupta
    Ice Cream Sandwich Dec 29, 2020
  9. LordPM
    Yes, ment no offense.
    Actually there isn't any setting available.
    This function should work right out of the bat.
    Did it worked earlier or it exist from the beginning.
  10. as_if_i_am
    It's from beginning in OnePlus 8t
    but works on my 6t.
  11. LordPM
    Try this.
    Go to the contacts app.
    Open settings.
    Click on contact sync settings.
    In this
    Tick the second opinion. "Also sync device contacts".
    This will sync the contacts on device or sim with google.
    This should resolve the search issue. If it's only searching with google.
  12. kheem
  13. JayKhokhara
    Cupcake Mar 29, 2021
  14. #15
  15. kamal.kv
    Honeycomb Mar 29, 2021
