Phone auto unlock
  1. B1547358465282
    Cupcake Dec 16, 2019
    B1547358465282 , Dec 16, 2019 :
    The phone is auto unlocked while in use for a long time. The long press hold upon any of the pull down tray options like wifi or hotspot, the phone is automatically unlocked.
    It is a very serious threat to the security of the person using it.
    G_plusone likes this.
  2. G_plusone
    Marshmallow Dec 16, 2019
    Cheetosdust likes this.
  3. B1547358465282
  4. G_plusone
    G_plusone , Dec 16, 2019 :
    I don't see any other reason for this to happen.
    Strange though
  5. B1547358465282
  6. Cheetosdust
    Starting Point Expert Dec 16, 2019
    Cheetosdust , Dec 16, 2019 :
    Please go to Settings -> Security & Lock Screen.
    Click where it says "Smart Lock" and enter your PIN.
    You should see four options. Can you please tell me what you see when you click them?
    Namely, if you have a place added to the "Trusted Places" or a device added the "Trusted Device" section.
  7. B1547358465282
    I have already checked for all those. There's no trusted device. Also, all the options are available to remove or update the security like (pattern, pin or password)
  8. B1547358465282
  9. Abhilash_PM
    Froyo Dec 16, 2019
    Abhilash_PM , Dec 16, 2019 :
    I recall there is an option somewhere where Google Assistant could unlock your phone and listen to your voice commands. I am taking a guess here.
