Phone broken. Need advice to extract data
  1. because21
    Froyo Feb 22, 2015
    because21 , Feb 22, 2015 :
    Hey guys, so I just broke the phone. The touchscreen is completely unresponsive. Tho, the phone itself is still on and giving me notifications as they come. My last backup was a while back. Wondering is any of you would know how to extract most of my data such as pictures, contacts,etc... since I can't manually put it in USB mode.
    Thank you very much, I will really appreciate your help
    Best
    Anneso
  2. feluda
    Lollipop Feb 22, 2015
    feluda , Feb 22, 2015 :
    All the contacts should be available from your Google account, unless you had local only contacts.
  3. because21
    Froyo Feb 22, 2015
    yeah, I just need to get access inside the phone with going into the phone settings since I cant do that. Plugging it through USB so far only allow me to charge the battery, not extracting anything out of it.
  4. 0verlord
    Gingerbread Feb 22, 2015
    0verlord , Feb 22, 2015 :
    That's why I always have debugging On over USB in case my screen ever goes unresponsive or get break. But you said you are able to charge the battery! Any good reasons why you can't access over MTP? Did you disabled the MTP when the phone was in good shape?
