phone charging reaaaaally slow
  1. markus9312
    Froyo Oct 27, 2014
    markus9312 , Oct 27, 2014 :
    Okay so I charge my phone, but it charges about 1% every 5-7minutes, and that's using the standard charger.. I tried charging it at different places etc but with the same charger, never works. I also tried another mini usb charger but same results..
  2. Zachsaxe
    Lollipop Oct 27, 2014
    Zachsaxe , Oct 27, 2014 :
    Do you have the phone on while charging and the OpO last all day so eternity charge will be fine
  3. Linanc7
  4. finaldentiny
    Community Veteran Oct 27, 2014
    carbine30 and Nilesh Sajnani like this.
  5. daunjan
    Froyo Oct 27, 2014
    daunjan , Oct 27, 2014 :
    the original charger should be fine, I had similar problem different charger was not strong enough.
    Phone needs a 5v 2amp charger as battery is big hope this helps.
  6. markus9312
    Froyo Oct 27, 2014
    yes it's on, and yeah the battery is amazing but that doesn't fix my problem :p it sucks waking up in the middle of the night and your battery is at 60%.
    Well I'm using it, and it should be fine but it isn't :/
    no, not gonna try that either since I need my phone in "normal" mode at all times.
  7. daunjan
    Froyo Oct 27, 2014
  8. IWantOneNow
    KitKat Oct 27, 2014
    IWantOneNow , Oct 27, 2014 :
    What if there is a problem with his micro USB charging port or something like that? Having to wait 8.3 hours for a phone to charge is laughable
  9. dwaynelson
    KitKat Oct 27, 2014
  10. markus9312
    Froyo Oct 27, 2014
    Tried that aswell, didn't work.
    Yes.
  11. flamingodise
    Ice Cream Sandwich Oct 27, 2014
    flamingodise , Oct 27, 2014 :
    The charging gets faster overtime. But your charging time seems way too slow. Probably a faulty adapter, cable or micro USB port. I hope it's not the last one.
  12. daunjan
    Froyo Oct 27, 2014
  13. dwaynelson
    KitKat Oct 27, 2014
  14. markus9312
    Froyo Oct 27, 2014
    Is it possible to check this somehow? Could this problem get worse? Cause I really really really don't want too send this back too china.
    Yep it's okay.
  15. martin.stefanov
    Jelly Bean Oct 27, 2014
  16. flamingodise
    I'm not sure if you can check it. Something could also be wrong with the battery or something. Maybe it's a software problem, who knows?
  17. dwaynelson
    KitKat Oct 27, 2014
  18. markus9312
    Froyo Oct 27, 2014
  19. markus9312
    Froyo Oct 27, 2014
  20. markus9312
    Froyo Oct 27, 2014
