Phone does not vibrate when on vibrate mode.
  1. Shounak_Katyayan Donut Jul 24, 2018
    Shounak_Katyayan, Jul 24, 2018 :
    I have a OnePlus 6 and when I switch the phone to vibrate mode, it does not vibrate when a call comes. The vibration setting is set to high for calls.
    mm8484 likes this.
  2. mm8484 Cupcake Feb 11, 2019
    mm8484, Feb 11, 2019 :
    I am facing same problem with 6T please suggest some remedy. It vibrates for WhatsApp calls and messages
  3. ngydat KitKat Feb 11, 2019
    ngydat, Feb 11, 2019 :
    In settings => System => Accessiblity => Vibrations, are all the vibrations enabled ?
  4. Sojib812 Cupcake Feb 11, 2019
  5. ngydat KitKat Feb 11, 2019
    Did you check my previous message ?
    Sojib812 likes this.
  6. Sojib812 Cupcake Feb 11, 2019
    Sojib812, Feb 11, 2019 :
    why brother? my all vaibration setting is on but still not working .. did you solve your problem?
  7. ngydat KitKat Feb 11, 2019
    Because I thought it was a possible solution since it worked for some people before
  8. Sojib812 Cupcake Feb 11, 2019
    but its not working for me [e]1f623[/e][e]1f623[/e]
  9. ngydat KitKat Feb 12, 2019
    ngydat, Feb 12, 2019 :
    You didn’t need to tell me that. You already told it in a previous message, remember ?
    My previous message is only there because you asked me « why? »
  10. Bobthesfd Donut Feb 12, 2019
    Bobthesfd, Feb 12, 2019 :
    Go to the Phone app -> Click the three gray dots in the upper right hand corner -> Settings -> Sounds and vibration -> Also vibrate for calls.
