Phone dying after battery gets lower than 15 percent
  1. chaitanyakhaitan
    Honeycomb Jan 2, 2015
    chaitanyakhaitan , Jan 2, 2015 :
    Hey has anyone else faced this issue. Battery dies after charge gets lower than 15 percent.
    Today I rebooted the phone at 16 percent charge with charger plugged in and the phone just died. Stock charger did not help for more than half an hour. Then used another charger to bring it back to life. Now charging with the stock charger.
    Any solutions?
    P. S. - I don't have issues with battery life, which is very good.
  2. Nurve
    KitKat Jan 2, 2015
    Nurve , Jan 2, 2015 :
    Try once clearing the cache from recovery (Vol- + Power button.) and restating after that. Hope it helps.
  3. chaitanyakhaitan
    @Nurve. Thanks will try that out and update here if it helps. Did you face the same issue at any point?
  4. kanagadeepan
    KitKat Jan 2, 2015
  5. v4v3n
    v4v3n , Jan 2, 2015 :
    I guess recovery is volume down + power and not volume up + power (this will take you to fast boot)
  6. vinojohn
    vinojohn , Jan 2, 2015 :
    My battery had gone down to 6 percent and put it on charging. Havent tested beyond 6.
    bnzjon likes this.
  7. chandresh87
    chandresh87 , Jan 2, 2015 :
    Well it is an issue with your phone because mine works even till 2 percent while watching videos
    So try to use battery calibration app from play store
  8. Nurve
    KitKat Jan 2, 2015
    Sorry. My bad. Edited and informed the person. Thanks for correcting me. Keep the good work up.
  9. Nurve
    KitKat Jan 2, 2015
    Recovery is Volume- and power button together. Sorry for wrong information. That will take you to fastboot. Yes ut happened to me only once. So i guess it is some random issue.
  10. v4v3n
    No worries mate..:):)
  11. v4v3n
    I also faced this issue, I did a factory reset and i calibrated my battery too(You need root access to calibrate the battery), but it didnt help me much. My battery got dead at around 7-8% after this. Now i have installed LiquidSmooth lollipop rom and I am on my first charge cycle and will see how the battery behaves on this ROM. This will confirm if it is a software issue.
    Nurve likes this.
  12. a_m3th
    Gingerbread Jan 2, 2015
    a_m3th , Jan 2, 2015 :
    Had the prob on another phone
    battery draining rapidly and dying at 15% or so.
    Just changed the battery and no more probs :D
  13. chaitanyakhaitan
    Thanks @v4v3n. Please keep us updated.
  14. chaitanyakhaitan
    Yup I had the same problem with one of my earlier phones. But in this there is no problem of battery life.
  15. chandrawanshi258
    Gingerbread Jan 3, 2015
  16. v4v3n
    Honeycomb Jan 3, 2015
    v4v3n , Jan 3, 2015 :
    The problem is still there with LiquidSmooth lollipop rom. Today my phones battery was dead at 25%.
  17. ileptonindia
    Ice Cream Sandwich Jan 3, 2015
    ileptonindia , Jan 3, 2015 :
    Discharge it zero then charge it 100% without powering on your device this fixed my problem earlier.
  18. chaitanyakhaitan
    Honeycomb Jan 4, 2015
    chaitanyakhaitan , Jan 4, 2015 :
    @ileptonindia How did you discharge it till 0??? when the phone dies at 15%.
  19. chaitanyakhaitan
    @v4v3n Let me know your course of action. Battery life is still great but just that you have it from 100 to 25 rather than having from 100 to 0. I am just hoping its not a hardware issue, software will be fixed in later updates.
  20. saju n a
    Gingerbread Jan 4, 2015
    saju n a , Jan 4, 2015 :
    Check your charging method. After fully charged phone is being used - battery is dying in fact to reach 0. If your use is heavy definitely it will not work long. You may be keeping the network data enabled always. You can disable it if not using the net. result will be tremendous.
