Phone exiting to home screen after ending phone call and other call switching issues
  1. BleedingShadow21 Donut May 19, 2019
    BleedingShadow21, May 19, 2019 :
    OS Version: 9.0.5
    Carrier: Jio(1), Vodafone(2)
    I have noticed that if I'm using another app apart from phone while on call, the phone exits to home screen when I hang up the call. For instance if I'm scrolling through Instagram while on call, after I hang up the call Instagram is automatically closed and will be exited to home screen. I have also noticed that I'm unable to switch between calls. Getting an error saying unable to switch calls keeping the first call on hold forever. Kindly help if you are having any solution for this.
  2. DVNK09 Honeycomb May 25, 2019
    DVNK09, May 25, 2019 :
    Go clear cache from recovery mode, let me know if that works.
    if not uninstall updates from phone application.
  3. BleedingShadow21 Donut May 26, 2019
    BleedingShadow21, May 26, 2019 :
    I cleared the cache from recovery and checked. The problem persists. Is there anything else that can be done?
  4. DVNK09 Honeycomb May 26, 2019
    DVNK09, May 26, 2019 :
    Did you uninstall updates?!
  5. BleedingShadow21 Donut May 26, 2019
    No I didn't. Which application in particular? The phone app?
  6. itsFreelancer Gingerbread May 28, 2019
  7. BleedingShadow21 Donut May 28, 2019
    BleedingShadow21, May 28, 2019 :
    I see, good to know. Thanks for the info. Will wait for the update.
  8. itsFreelancer Gingerbread May 28, 2019
    itsFreelancer, May 28, 2019 :
    In the meantime, do you remember if you downloaded any apps that can save battery? If yes, it could be the reason ehyyour apps are getting killed.
  9. BleedingShadow21 Donut May 28, 2019
    Actually the apps are getting closed automatically the moment I hang up the call. I will usually be using an earphone while taking. The same time I'll be browsing or something. So when I hang up the call..that particular app that I was using is getting closed. Nothing else.
