Phone goes into vibration due to volume up and power button missing calls almost everyday via OnePlus 9R
  1. ShailPadhiyar
    Cupcake Sep 17, 2021
    ShailPadhiyar , via OnePlus 9R , Sep 17, 2021 :
    Phone goes into vibration mode due to accidentally pressing of volume up and power button. missing calls and notification almost everyday. It is very irritating. There is alert slider for the specific features in my phone so no need of this feature Kindly let me know how to disable it.
    Device: OnePlus 9R
    Os version: Oxygen OS 11.2.4.4. LED28DA
    Android: 11
  2. Aaron2017
    Lollipop Sep 17, 2021
    Aaron2017 , Sep 17, 2021 :
    Yes, that is the Android shortcut to put the phone on vibrate mode and you can't disable that. All you can do is send feedback about it here
    I have done that as well as it happened to my quite a lot too in the past.
  3. Swejuggalo
    OnePlus 9 Series Expert Community Expert Sep 17, 2021
    the_o2 likes this.
  4. Aaron2017
    Me neither, first i thought it was a region thing, but you're from Europe, same as me, and the combo does nothing for you but is does for you. And this user if from India, where i thought the combo did nothing as well.🤷
  5. the_o2
    OnePlus 9 Series Expert Community Expert Sep 18, 2021
    the_o2 , Sep 18, 2021 :
    I'm from India and this never worked me for as well,
    Tried on OnePlus 5, 8T and 9 Pro :sweatsmile:
    Aaron2017 likes this.
  6. ShailPadhiyar
    Cupcake Sep 18, 2021
    ShailPadhiyar , via OnePlus 9R , Sep 18, 2021 :
    It is not android features I think.
    I've tried in my other brands android devices it did nothing on these phones.
    However if anyone knows how to disable the feature, it will be helpful.
    Thank you..
  7. Aaron2017
    Lollipop Sep 18, 2021
    Aaron2017 , Sep 18, 2021 :
    It is, it works the same on my Google pixel 3XL. You can read this article about it from 3 years back, it was introduced with Android 8
    https://www.androidpolice.com/2018/05/08/android-p-new-incredibly-awkward-ring-mode-shortcut/
    And you can't disable it, the phone manufacturers have to do that. That's why it doesn't "work" on other brands their phones.
  8. Aaron2017
    For me it has always been this way on all my phones, except the ones i had from Samsung. On the original pixel, pixel 3XL, my 7t pro, 8 pro, and on the 9 i recently got my hands on as well.🤷
    the_o2 likes this.
  9. the_o2
    This is a bug with few OnePlus users, by default it must be set to none as OnePlus have the Alert Slider, as there is no option to find that settings as in pixel. So.
    This worked for many users, but yes, it need PC, ADB and all
    https://www.reddit.com/r/oneplus/comments/n2oufw/psa_how_to_disable_the_volume_up_power_button/
    BTW report this issue here
    They might give you some zip file to solve it.
  10. Aaron2017
    Yup, that's why i reported it. Didn't know about the ADB thing tho. Maybe it'll get removed with Android 12 and the new codebase. Doesn't bother me anymore because i learned how to pick up my phone differently so it doesn't get triggered anymore.
    the_o2 likes this.
  11. Akshat Sehgal
    Ice Cream Sandwich Sep 18, 2021
    Akshat Sehgal , via OnePlus 9R , Sep 18, 2021 :
    Same. I tried this on my 9R just now and it doesn't work.
    the_o2 likes this.
  12. Nipu_1998
    The Lab Reviewer - OnePlus Nord 2 Sep 18, 2021
    Nipu_1998 , Sep 18, 2021 :
    The combo does nothing for me.
    As @the_o2 suggested, this might be a bug in the system which occurs only in some devices.
    the_o2 likes this.
  13. Swejuggalo
    Swejuggalo , via OnePlus 9 Pro Morning Mist , Sep 18, 2021 :
    Happen to have been transferring data and settings from a other phone either via Switch/Clone or Google backup?
    Must be some logical reason why some have it and some don't.
  14. #14
  15. Swejuggalo
    OnePlus 9 Series Expert Community Expert Sep 19, 2021
    Swejuggalo , via OnePlus 9 Pro Morning Mist , Sep 19, 2021 :
    7 Pro, 8 Pro, 9 Pro, Nord CE. That button combo does nothing on any of them. (unlocked EU versions)
  16. BeingIncog
    Nougat Sep 19, 2021
