Q1603075606619 , via OnePlus 8T , Jan 20, 2021 : Hi, my phone is hanging a lot while using it and its not responding to any back or home gestures. Please look into this issue asap.
Anish De , Jan 20, 2021 : Is it happening when you are doing anything specific (gaming, video rendering etc.)?
Q1603075606619 , via OnePlus 8T , Jan 20, 2021 : Its happening while i am navigating through apps. For eg its not working while i navigate from whatsapp to any other app. I have a screen recording video of the issue i am facing.
Anish De , Jan 20, 2021 : Can you upload the screen recording? Also are you running any beta version of oxygen os?
Q1603075606619 , via OnePlus 8T , Jan 20, 2021 : There is no option to upload the screen recording in this community app. And also i am not using any beta version. I can send the screen recording via an email if the email address is provided.
J1607406597791 , Jan 20, 2021 : I'm having the same problem. Mostly while I'm browser. Turning off RAM boost surprisingly helped. I think tbh I'm leaking memory like a faucet. Dns cache problems and permissions settings have been resetting often to, which I think has to do with the way sync works (how often/when) with retrieving keys for credentials.... I'm no red hat but I like to pay attention to the the mini debug logs that run seemingly ALWAYS. Where you report questions and concerns/comments in Google apps or some system apps is a "?" Mark. You can often press that, and/or find Help/report a problem, it'll pull up an email to send to Google or whoever (probably Dropbox...... Or OP). Before sending it (if you choose to do so) and you want to hurt your brain , try reading through Event/system logs. Or checking a applications running. Writing this my window froze 2x. Hardware layer is fine cause I can 3 -button quick jump to Home /wallpaper background , then tab back and it'll correct itself.. Btw I'm new hi everyone 😁7+T
J1607406597791 , Jan 20, 2021 : Make a copy , save/upload it to your Google drive account, then go there from a secure computer you trust, upload the link by sharing it. You can do this with a URL link it gives you for this purpose. Just make sure it's not able to show any personal info you didn't want seen (not that it really makes a difference nowadays) ... Oh yeah and there's always youtube.. if you're already signed in, it doesn't even require much setup if any, about as easy as sending a message to anyone.
Ackblade , Jan 20, 2021 : Same things happening to me with gestures. All I've done is turn the phone off and then turned it back on and it worked after that
