Third Party Software Phone hangs for a sec.
  1. xalmaan
    Donut Jul 3, 2020
    xalmaan , Jul 3, 2020 :
    my phone hangs for a second everytime I slide "Back" twice. it hangs for enough duration and I could even manage to take a screen of it. you can see on the right below. the back arrow is still stuck there.
  2. Gaston NP
    Lollipop Moderator Jul 22, 2020
    Gaston NP , Jul 22, 2020 :
    Hi,
    You can try to uninstall and reinstall the application.
  3. xalmaan
    Donut Jul 22, 2020
    xalmaan , Jul 22, 2020 :
    I just realized. It is not just this app. every app I am facing problems of one sec delay while navigating.
  4. Cosmos_NT , via OnePlus 7T Frosted Silver , Jul 23, 2020 :
    It is because of the Gboard. There's a close button at the bottom when Gboard is open, if you try to close the app while Gboard is still on, you'll face that lag, but it is mostly seen when you're typing anything and suddenly decided to close the app.
    To avoid it just press the downward facing arrow at the bottom before you try the back gesture.
  5. xalmaan
    Donut Aug 6, 2020
    xalmaan , Aug 6, 2020 :
    Thanks for that. But I am very sure Gboard has nothing to do with it. Because it was just whatsapp attached a screenshot of. However, it happens to me mostly when I use the side back gesture. And happens very often.
