Phone Heats Up
  1. anshuman2105
    Cupcake Sep 1, 2017
    anshuman2105 , Sep 1, 2017 :
    hello. ever since I have uploaded my software to the latest one, the phone is getting heated up at the ear piece end even when lying idle. this problem wasn't there earlier and it's a great phone otherwise.
    can you please tell me what is going wrong because the handset is pretty hot even as I type this.
  2. frankkn85
    Eclair Sep 10, 2017
    frankkn85 , Sep 10, 2017 :
    yes even I'm facing this same issue on my 3T I'm having oxygen 4.1.7 update installed
  3. lostLambda
    Lollipop Sep 10, 2017
  4. RoderickChandra
    Eclair Sep 10, 2017
    RoderickChandra , Sep 10, 2017 :
    May be, Backing up all u want to save and hit a complete factory reset could solve the problem. Normally heating of battery while charging, charging with WiFi or data on or even while using WiFi data and charging is normal but if it heats too much then the phone is designed to shut down. But the best I feel for you is to get it checked at the service centre
