Battery/Charging Phone itself
  1. Mysticlady88
    Cupcake May 23, 2019
    Mysticlady88 , May 23, 2019 :
    Okay my phone keeps hitting while charging. And I haven't kept it on the charger forever though. I usually charge it til it says 100% but now sometimes even if it's low battery and I'm trying to charge it the phone hits up!
  2. BobbyV8_
    The Lab² Reviewer - Insta360 GO 2 May 23, 2019
    BobbyV8_ , May 23, 2019 :
    What do you mean by hitting? Do you feel any kind of shock or electric currents when you hold the device? If yes, then it's due to non availability of earthing.
    Electronic surrents pass through the metal body of the dwvice amd we feel it when holding. Using a case can eliminate this though
  3. Mysticlady88
    oh sorry meant heating ***
  4. Mysticlady88
    No, it's more of the phone is burning up when it's charging
  5. BobbyV8_
    Device heats up while charging, however there shouldn't be too much of it. Can you install any battery temperature app and show the heat battery is having?
    It could be due to bad battery or any background processes running while the battery is charging. Make sure you close apps while charging and do not use it. If it syill happens, it could be due to faulty battery
    Mysticlady88 likes this.
