Phone not charging.(One plus9R)
  1. AmanP1701
    Cupcake Sep 23, 2021
    AmanP1701 , Sep 23, 2021 :
    I was charging my phone this morning and my battery percentage got stuck at 80 whil charging now the battery is draining but the Phone is jot charging even with different one plus charger which is working just fine now I am out in a different city and can't charge my phone what an I supposed to do?
  2. the_o2
    OnePlus 9 Series Expert Community Expert Sep 23, 2021
    the_o2 , Sep 23, 2021 :
    Usually charging stuck on 80% if the optimised charging option is enabled and it gives a message too.
    Disable the optimised charging and restart your phone once and see
    Shailender Sharma and Dresa91 like this.
  3. Dresa91
    User of the Year 2016; Most Active User 2020 Sep 23, 2021
    Dresa91 , Sep 23, 2021 :
    In addition to:
    Can you please clean the USB port?
    Shailender Sharma and the_o2 like this.
  4. AmanP1701
    AmanP1701 , via OnePlus 9R , Sep 23, 2021 :
    I will try it wait
  5. AmanP1701
    Disabled it still not charging
  6. Dresa91
    What about:
  7. AmanP1701
    Yeah I checked it's clean the other one plus device is charging perfectly
  8. AmanP1701
  9. the_o2
    Is it stuck on 80% ?
    Can you post a screenshot.
  10. Dresa91
    How did you clean it?
    Shailender Sharma likes this.
  11. AmanP1701
    It's not stuck on 80 bro the battery is draining but the Phone is not charging not with a different charger and the other Phones are charging from my charger too the battery is 52 now still not charging
  12. AmanP1701
    It's not about the port bro I tried with a different one Plus charger too and the other phone one plus Nord 2 is charging properly from my charger so yeah not this issue
  13. AmanP1701
  14. Dresa91
    Did you try another charger?…or what do you mean?
    I am talking about the USB port on your device
  15. AmanP1701
  16. Dresa91
    Can you please check the charging behavior in safe mode?
    the_o2 likes this.
  17. AmanP1701
  18. AmanP1701
  19. Dresa91
  20. AmanP1701
    Rebooted in safe mode it was still not charging I came to a different city as of now I will go home and try to charge it again tell me there I another way or I will visit the service center
