phone not starting
  1. g.ram.vj
    Cupcake Sep 5, 2019
    g.ram.vj , Sep 5, 2019 :
    This is from my friend when he turned his camera on, his phone got hanged and turned off and now its not starting he tried hard reset also it didnt help
  2. GrooVek
    Eclair Sep 5, 2019
  3. g.ram.vj
    Cupcake Sep 5, 2019
  4. GrooVek
    Eclair Sep 5, 2019
    GrooVek , Sep 5, 2019 :
    He installed other version like factory. I mean he installed camera for OnePlus 7(Pro) or something
  5. JAexclusive1
    Donut Sep 5, 2019
    JAexclusive1 , Sep 5, 2019 :
    connect your phone to pc and try holding power + volume up button combination simultaneously, if your pc can detect your mobile then you can use unbrick tool to make your phone back alive.. ( all data will be erased in this process )
    if your device is under warranty then you're welcome to bring your device to OnePlus service centre..!
  6. g.ram.vj
    Cupcake Sep 5, 2019
  7. g.ram.vj
    Cupcake Sep 5, 2019
    any other option?
    and also phone isn't under warranty as it got over in August
  8. GrooVek
    Eclair Sep 5, 2019
    g.ram.vj
    any other option?
    and also phone isn't under warranty as it got over in August​
    Send to the service then. Maybe something with motherboard
  9. JAexclusive1
    Donut Sep 5, 2019
  10. g.ram.vj
    Cupcake Sep 6, 2019
    g.ram.vj , Sep 6, 2019 :
    it's giving a buzz after doing your said method..but the device isn't showing on pc
  11. sushanth_goud
    Eclair Sep 10, 2019
    sushanth_goud , Sep 10, 2019 :
    Try to remove the sim cards from the device and connect your phone to a charger. Now long press on power button for 30 seconds continuesly and see if your device gets restarted.
  12. Priyanshu Sharma
    Jelly Bean Sep 11, 2019
