phone restart issue
  1. shoeb807
    Cupcake Dec 29, 2018
    shoeb807 , Dec 29, 2018 :
    I am facing the issue of phone automatic restart from last few days can anyone help me with this?
  2. obol2
    Ice Cream Sandwich Dec 29, 2018
    obol2 , Dec 29, 2018 :
    When does this happen? So you have automatically restart turned on?
  3. Catalin_Buzescu
    Jelly Bean Dec 29, 2018
    Catalin_Buzescu , Dec 29, 2018 :
    I've seen a lot of people complaining about this after upgrading their Oneplus 5/5T to Pie.
    After any major update, any user should try a factory reset and clean install. It does wonders.
    Just save all data with Oneplus Switch, copy the backup on your pc, and after clean install, copy it back and restore.
    It's the safest way!
    sweggitity likes this.
  4. Multiplatform Gamer
    Multiplatform Gamer , Dec 29, 2018 :
    i confirm it doesn't work. after total factory reset the phone reboots even more often not letting people complete the initial setup. the best thing to do is a downgrade to android 8.1 to oxygen 5.1.7 sadly.
  5. reshab_aga
  6. ziyauorrahamans
    Gingerbread Dec 30, 2018
  7. slipd
    Froyo Dec 30, 2018
    slipd , Dec 30, 2018 :
    Hi guys,
    Had this issue myself, ended up downgrading from Pie because of bugs (Play Store/Bluetooth etc.) and my device (OP5) got stuck in a bootloop... See here.
    Hope my experience helps someone ;)
  8. sweggitity
    Ice Cream Sandwich Dec 30, 2018
    sweggitity , Dec 30, 2018 :
    No issue with me, been using Pie, since 26th december, i did a clean install. Apart from the missing Bluetooth icon, everything is working smoothly
  9. Multiplatform Gamer
    Multiplatform Gamer , Dec 30, 2018 :
    you're lucky. i might just go back to 5.1.7 and flash a custom rom instead.
  10. dj_romy_fi
    Cupcake Jan 3, 2019
    dj_romy_fi , Jan 3, 2019 :
    Well my 5 9.0.0. boots to this "endless boot loop" every time I want to take a screenshot or I boot the device.
    The annoying thing is that the text based menu flashes on the screen <1s and it's kind of annoying to try to figure out what is the correct button sequence to do the boot :p
