phone restarted while using social sites.... like insta
  1. U1535892517436 Eclair Jun 18, 2019
    U1535892517436, Jun 18, 2019 :
    hey, i am facing an issue with my OP6 while using social app like FB or Insta my phone restarted like lights are off for 5 to 7 sec then showing a logo of OP then instantly switched on and asking for pattern to unlock.
    i am facing this issue from last 1 and half month ..during this period it happens 3 times ...the latest one is at 5 min before this post/thread.
    please suggest me what to do ....thanks for your suggestions in advance [e]263a[/e]️[e]1f603[/e]
  2. toastytoast1234 Marshmallow Jun 18, 2019
    toastytoast1234, Jun 18, 2019 :
    I would suggest getting a sharper suit, but you seem to have that covered already.
    Is it just those, or apps like those?
    Kytharsis likes this.
  3. U1535892517436 Eclair Jun 18, 2019
    i m using FB and insta only ... and faces this issue with both the apps
  4. meatandy Oreo Jun 18, 2019
    meatandy, Jun 18, 2019 :
    Must be a FB app problem . Delete app and reinstall.
  5. U1535892517436 Eclair Jun 19, 2019
    U1535892517436, Jun 19, 2019 :
    i m using FB and GB insta
    phone restarted 1 time while using FB and 2 times while using GB insta...is it possible that both the apps may have the same problem?
    as you suggest i will uninstall and re install the above apps ... but according to me both apps can't do same behaviour.
