phone ringer stuck on vibrate
  1. R1561598923024
    Donut Feb 18, 2020
    V1579217746004 likes this.
  2. R1561598923024
    Donut Feb 18, 2020
  3. spot01
    Jelly Bean Feb 18, 2020
  4. Melkuse Daniel
    Ice Cream Sandwich Feb 18, 2020
    Melkuse Daniel , via OnePlus 7 Pro Nebula Blue , Feb 18, 2020 :
    Bro, I think you turned on vibrate using the alert slider, if alert slider is moved to centre position then the manual change using volume and in settings will not work, so check whether the alert slider is set to ring mode, if it is placed in center then slide it back to down.
    Let me know whether this solved your issue...
    X1567689078371 likes this.
  5. R1561598923024
    Donut Feb 21, 2020
    R1561598923024 , Feb 21, 2020 :
    the middle slider will not move. the icon underneath (vibrate) will not change.
    it's the same in the settings...
  6. R1561598923024
    Donut Feb 21, 2020
    that thread has so many replies... there is no way OnePlus would look at that.
  7. spot01
    Jelly Bean Feb 21, 2020
    spot01 , Feb 21, 2020 :
    That is the only place they will look this is just a user forum no one from OnePlus support looks here
  8. R1561598923024 , via OnePlus 7 Pro , Feb 21, 2020 :
    kk I just submit a bug report and put it on that thread. thanks
  9. U1586392065261
    Cupcake Apr 9, 2020
  10. U1586392065261
    Cupcake Apr 9, 2020
    U1586392065261 , Apr 9, 2020 :
    my phone is stuck on vibrate. the slider key does not work. restarting phone does not work. shutting down for minutes does not work. please help
  11. Melkuse Daniel
    Ice Cream Sandwich Apr 9, 2020
    Melkuse Daniel , via OnePlus 7 Pro Nebula Blue , Apr 9, 2020 :
    If the alert slider doesn't work then you can't change it in settings because software cannot override the hardware specifications.
    So kindly get it repaired in the service centre.
  12. BIGVIC39
    Cupcake Mar 25, 2021
    BIGVIC39 , Mar 25, 2021 :
    This happens to me too! Only the last 2 months or so. WHEN I put the slider to silent, THEN put the slider back to sound, the RINGER stays on vibrate and will NOT allow volume increase. Only by rebooting the phone does the volume option return....ANNOYING and needs a fix!
  13. Melkuse Daniel
    Ice Cream Sandwich Mar 25, 2021
    Melkuse Daniel , via OnePlus 7 Pro Nebula Blue , Mar 25, 2021 :
    In this case it might the software bug, report this bug straight away via feedback tool.
  14. T1623859741699
    Cupcake Jun 16, 2021
    T1623859741699 , Jun 16, 2021 :
    The oldest posts like this are from 2017. This company clearly don't give a **** so I will buy something else next time. Maybe with iOS instead of this crap.
  15. Artemus.
    Community Hero 2020 Jun 16, 2021
    Artemus. , Jun 16, 2021 :
    Just a little FYI, no one from OnePlus reads these threads.
    GamingDoggo likes this.
