OxygenOS phone suddenly requests PIN instead of swipe code
  1. mrMojo
    Cupcake Nov 29, 2016
    mrMojo , Nov 29, 2016 :
    Hi,
    I have activated the fingerprint reader on my OnePlus 3T. As such I was asked for a backup security measure, which will be asked for after each reboot, and there I chose the security swipe pattern.
    Until this morning everything worked as expected and I had to use my security swipe pattern once, at the beginning of each session.
    Then suddenly something changed and the phone is now asking for a PIN code instead of a swipe code, only problem is: I have never set a PIN code, so of course I don't know it!!
    Is there any way to switch the PIN code back to a security swipe pattern or disable it all together? If I don't find a solution I will have to reinstall everything from scratch, which I would really like to avoid. Any help greatly appreciated!
    Thanks,
    -Markus
  2. hgoor
    Gingerbread Dec 2, 2016
    hgoor , Dec 2, 2016 :
    If you have a backup you don't have to reinstall anything.
