phone's overheating
  1. MD_18
    Honeycomb Jun 25, 2018
    MD_18 , Jun 25, 2018 :
    I play Pubg a lot and Never experienced overheating at all. The maximum temperature was around 38-39c but after updating to 5.1.8 oos phone's overheating. It becomes difficult to hold it after 10mins of gaming. maximum it achieved was 47c this time.Also the battery life is shit. it's dropping faster than ever. I know there are few threads mentioning the heating issue but none of them stated 47c so is this normal or my phone's going crazy? I've attached a screenshot of Normal usage temperature.
    I mean what's the point of investing 35k for this heater.
  2. NeverGiveUpOnUrDreams
    Lollipop Jun 25, 2018
    Prcko likes this.
  3. MD_18
    im not able to play at all. within 15-20mins the phone crosses 45c.
  4. Prcko
    KitKat Jun 25, 2018
    Prcko , Jun 25, 2018 :
    you know what is overheating? your body have 37 degrees what you feel in 44 degrees? how many degrees have outside? please think normally
  5. MD_18
    outside is 32c. also for your kind information the phone's not supposed to cross 45c. if it is then it's called overheating.
  6. Prcko
    KitKat Jun 25, 2018
    you play PUBG so you must wait some heat. it's normal
  7. MD_18
    well then what's the point of having sd845 and 6gb of ram if it's gonna perform like Oneplus 3. Also its not supposed to heat like this. it started after 5.1.8 update and also other phones with same configuration doesn't heat like this. So if you have any solution regarding this then do write otherwise stop making useless comments.
  8. Prcko
    KitKat Jun 25, 2018
    so post your battery life screen shot. many problems was about android system or Google play services. peace man we want to try help you.
  9. MD_18
    Prcko
    so post your battery life screen shot. many problems was about android system or Google play services. peace man we want to try help you.​
    android system and Google play services are normal. it's just that phone is heating after the recent update. i didn't have this problem before. now if i do browse for few minutes i can feel the heat which wasn't there before. Also battery is draining quite rapidly and one of my friend is also facing the same issue after 5.1.8
  10. Prcko
    KitKat Jun 25, 2018
    did you try wipe cache in recovery?
  11. MD_18
    yes 2-3 times. i even did a factory reset just after updating my phone to 5.1.8 but i think it's not working.
  12. Prcko
    KitKat Jun 25, 2018
    can you post here your battery life screen shot?
  13. F_DinuShan_Dayalan_SovE
    Cupcake Jun 25, 2018
    F_DinuShan_Dayalan_SovE , Jun 25, 2018 :
    same problem.. when mobile data is turned on and if the phone is charging.. too much heat. also when playing pubg phone becomes a heater. have used oneplus5 for a year.. never faced such issues
  14. DARTH 007
    KitKat Jun 25, 2018
  15. Dark_Matrix_Guru
    Ice Cream Sandwich Jun 26, 2018
  16. MD_18
    Honeycomb Jun 26, 2018
    MD_18 , Jun 26, 2018 :
    im complaining about 47c and that's not normal.
