3
Phonw is going to hang state and switch off it self after updating 5.1.6
  1. Ajith Gowda C T
    Eclair Jun 12, 2018
    Ajith Gowda C T , Jun 12, 2018 :
    Hi Team,
    Phone is going to hang state,getting heated and switch off it self after updating 5.1.6. I can see blue light in notification led once screen goes blank. Automatically phone will lock . seriously OnePlus has to address this issues immediately.
    Please fix this ASAP.
    thank you
  2. sanjaisingh8888
    Cupcake Jun 12, 2018
    sanjaisingh8888 , Jun 12, 2018 :
    Same problem is here since latest update.. OnePlus team fix it as soon as possible. It is too much frustrating with such a high brand device.
    Ajith Gowda C T likes this.
  3. Hardik Thaker
    Hardik Thaker , Jun 12, 2018 :
    I had same issue just now. I already read this post and as soon as it happend with me I search this thread again and post this.
    phone was is ideal state from 4 hrs as I was sleeping. Then I got a call, while I was talking on the phone, after 20 to 30 seconds the voice of other person got stopped, when I looked at the phone there was only a light blue light on notification LED and nothing was happening. I had to hard reboot my phone by pressing power button for 10 seconds.
    sanjaisingh8888 likes this.
  4. sanjaisingh8888
    I contacted to the OnePlus team but they didn't give me a satisfying answer. The member of ONEPLUS support told me that it is due to third party application. Use phone in safe mode. But when we use our mobile in safe mode then no any third party application will work and the mobile will become a empty box only.
  5. SanketGolechha
  6. Hardik Thaker
  7. gubro
    KitKat Jun 12, 2018
    gubro , Jun 12, 2018 :
    is hang state in India?
  8. SanketGolechha
  9. girishgb
    girishgb , Jun 12, 2018 :
    This is happening to me as well. It happened more than 5 times now from morning . We need a fix ASAP
  10. kaghedo
    Jelly Bean Jun 12, 2018
    kaghedo , Jun 12, 2018 :
    This could be a bug and you can report it using the below link:
  11. the_o2
    OnePlus 9 Series Expert Community Expert Jun 12, 2018
    the_o2 , Jun 12, 2018 :
    Try these 2 things..
    First: Go to setting->storage and memory (scroll down)-> cached data(click and clear the cache).
    and then
    Second: Wipe the cache partition from recovery mode by following step.
    1. Turn the phone off(unplug the charger if charging).
    2. Hold Power and Volume Down
    3. English (or pick any language that you want)
    4. Wipe data & cache
    5. Wipe cache (it's doesn't delete your personal data)
    6. Yes
    7. Reboot.
  12. iNtEnSePL
    KitKat Jun 12, 2018
  13. sanjaisingh8888
    I have tried above method but problem is still there.
  14. sanjaisingh8888
  15. Pradeep.goldy
    Pradeep.goldy , Jun 12, 2018 :
    I'm also facing the same problem.
    My OnePlus 6 is hanging very frequently after I update the new Oxygen OS 5.1.6
    Blue light used to turn ON automatically and constantly and No Button responds!
    I tried wiping out the cache but the problem still exits
    OnePlus TEAM --> Please help to Correct This Problem on your Flagship Phone ASAP!
  16. girishgb
    Tried this fix and it didn't work
  17. Pradeep.goldy
  18. the_o2
    Report here :
  19. Cervantes
    Moderator Moderator Jun 12, 2018
    Cervantes , Jun 12, 2018 :
    Try cleaning the system
    save important information
    Factory reset
  20. izzykasha
    Lollipop Jun 12, 2018
    izzykasha , Jun 12, 2018 :
    Is this just an A6000 model issue or does it affect the A6003 models too, just trying to see if there is an issue with models
