[CONTINUATION]
What I usually do here is play around and see what pleases my eyes. My parameters for this picture are as follows:
I will skip the HSL/Color Panel as I will show you the power of this panel when I will edit my second picture which is shot in day light. It will better show you the effects of this panel.
Next up is the Split Toning Panel that looks like this:
As you see from the image above, we have 5 sliders. Two for highlights – hue and saturation and two for the shadows – hue and saturation and the last one which is called the Balance slider is responsible for pushing or pulling the balance towards either the shadows or highlights. Why should we use Split Toning? The reason to use Split Toning is to manipulate the colors independently in the highlight and shadow areas. For example, let’s say you notice in a picture that you have to much yellow in the highlights due to lots of lamp posts around. Perhaps your shadows are extremely blue because of the sky. You can add more blue to the lamp posts without damaging the sky in the shadows, as those might be blue already. Before continuing further, I will stress this – Split Toning is a creative process, so there is no right or wrong, it’s how you envision your picture. The best practice is to play around with it to see what are the changes and how they affect your image overall. Getting back to my picture, I want my image to pop out a little because right now it’s still too dull. So, I’ll play around with it until I find that I am pleased with my final results. These are my results for this picture:
Big difference, right? When playing around with the Split Toning, I wanted the colors to come as much close to the real colors of the Cathedral Twin Towers. That is how they look like. That pop that I was talking there is there.
Moving on, I will edit the Details Panel.
Looking at the picture above, we can already see there is lots of noise. We want to reduce noise as much as possible but at the same time keep a lot of details in the picture. This is tricky, very tricky to do. Most people I see are struggling with this panel. Let me tell you exactly what I do. First I tackle the Color Noise slider. Why? Because it’s the most easiest to fix. When you will move your Color Noise slider to the left, you will see blotchy spots disappear. The default color noise setting is usually 25 and it works well but you may want to increase it if you still see blotchy spots in your picture. The Detail and Smoothness sliders under the Color Noise Slider you leave as they are. Next, let’s tackle the Luminance Noise. Before doing this, zoom into your photo so that you can see the noise really well. After zooming in, then adjust your luminance noise. Go from 0 to 10. If you still see there is noise, then increment it from 10 to 20. Repeat with increments of 10 until you see the noise is almost gone. Increase the detail under the Luminance Noise slider from 50 to 60. Lastly, go into your Sharpening slider and increase with increments of 10 until you see that there is good detail without the introduction of noise. Look at bright areas while adjusting the sharpening slider as you will see more clearly the detail on those parts. The most important part in Sharpening is the Masking slider. What does the Masking slider do? I call this slider the “Magic Slider” as it will look for solid or smooth areas and try to “mask” or remove the sharpening from those areas. To see what will get sharpened and what won’t, press your ALT button and then while still holding your ALT button on your keyboard slide your Masking slider to the left and you will automatically see that your image will turn into black and white. See the picture below:
The black areas are the areas that are not going to be sharpened, while the white areas are the areas that will be sharpened. I usually set my Masking slider between the values of 60 – 90 depending on the sharpening I want applied. Experiment with it.
Next, I crop the image to make it neat and for it to stand out. Click the Crop tool
and think about how you want to crop the image or if the image should be cropped at all. This is my cropped image:
The adjustments that we made were all global adjustments, meaning that they affect the whole picture. The fun begins with the local adjustments. Where are the local adjustment tools? Look at the photo below:
Let’s start from the far left. The first tool from the left side is called the Graduated Filter tool. Its job is to apply a range of effects on a selected controlled part of a photo. For example, if the Graduated Filter tool is mostly used to enhance the skies and waters in landscape photography. I can control the direction of the Graduated Filter tool. This tool has a range of effect options like these:
As you can see at the top of the menu, there are three tabs named "New", Edit" and "Brush". "New" is initially active by default. When you press the new button, you create an additional graduated filter. From there you can hover your cursor to any part of the photo, click and drag the graduated filter down, sideways, to the top, in which way you want. This will be the areas that will get affected. From those range of effects I mentioned earlier you can adjust to your liking. Experiment with these to make your pictures pop out more but don’t overdo it.
As in the picture above, the green highlighted part is showing you where the mask overlay will be applied. By default this is turned off, so the yellow highlighted part that reads, “Show Selected Mask Overlay” please check it on so that you know what parts in your picture you want to apply effects.
The next tool after the Graduated Filter tool is the Radial Filter tool. This tool is an awesome tool that is used mostly in portrait photography but can be used in all types of photography too. It has the same range of effects as the Graduated Filter tool. (Tip: When you first apply a Radial Filter tool, you will automatically notice that the green highlights are outside of the circle instead of inside. Go to your Radial Panel and at the bottom click on “Invert Mask”. This will make the range of effects apply only inside the circle.)
Before:
After:
The last tool is the Adjustment Brush tool.
With the Adjustment Brush tool you can modify specific image areas. You can easily manipulate single or multiple photo parameters like exposure, white balance, sharpness, noise, etc. The range of effects is the same as the other two.
Getting back to the picture I am editing, I am going to use the Adjustment Brush to brush over everything except the Cathedral Twin Towers Church. Why? Well, I can reduce more noise. But why would I do this if I already did this in the Detail Panel? Simple, I have more control over what part of the images area I want to reduce the noise. The second reason is because this picture was really noisy especially in the shadows as this picture wasn't properly exposed to the right.
After applying the noise reduction using the Adjustment Brush tool, I then go back to my Detail’s Panel and reduce the amount of noise I applied, but increase the sharpness just a little.
I will also add another Adjustment Brush and paint it only on the area of the sky and will play with the Temperature and the Tint. For my Temperature, I will put a value of -38 to add a cool atmosphere to the picture and a Tint of value +9.
I still don’t like the image because the bottom part bothers me a lot.
It lacks the detail and softness is creeping in there because probably I applied noise reduction, but we can fix this somewhat better. I am finished with my local adjustments so now the reason I told you before that I will come back to the Basic’s Panel is to do some final touches. I will add some contrast with a value of +11 and some clarity with a value of +30. I will make the image pop out more by increasing the Vibrance to a value of +20 and the Saturation to +25. I will bump also the exposure to +0,26.
The last thing I do after finishing up with the Basics Panel is look into the Effect Panel to see if some vignetting can be applied.
I usually see if vignetting works for a particular picture or not. With this picture I am editing, I decided not to include it as I like it the way it is. Next, I am going to go to the Lens Correction Panel and check the “Remove Chromatic Aberration” box. Chromatic Aberration is simply put, distortion of the lens. In a picture, you can see mostly chromatic aberration in dark edges next to bright images of an image. Its effect resembles more like a ghosting effect in purplish color. I would check also “Enable Profile Corrections” except there is no profile for OnePlus devices. There is however a profile for Samsung Galaxy phones and Google Pixel’s, just FYI.
Phewwww, I am done with editing.
Let’s take a look at the before and after image.
Like night and day
I would like to say a few words about the picture I chose. I chose this because it is a hard edit. I wanted to show you my fellow Community members a picture which was underexposed with a lot of noise on how to tackle this kind of problem which most of us probably experience. Most of you see the picture on a computer screen and say ewwww look at how nasty that picture is with all of this noise and dark areas which I can barely make out. Well, as I showed you here, nothing is impossible. Of course, the picture wont’ be picture perfect but at least you did the right editing to make it much better than your original picture. To make your editing life a lot easier, then do the Tips that I suggested to you.
Part II is still in the making and it will be a day time picture. So stay tuned for this. Follow me if you are interested in this guide.
Before I part, I have a challenge for all of you who are up to it
The challenge is simple. I have the RAW file of this picture I edited, show me what you can do with this file. Maybe you guys will edit much better than me
We are all here to learn. So please, take the RAW file, show me your editing skills on how you would edit this picture and upload it to your Google Drive and let’s get this rollin’!
Thank you everybody for visiting this thread and as always, go out there and shoot some pictures!
Google Drive link to my RAW file:
https://drive.google.com/open?id=1PeOEpE4ftSL8qm7-9FSsH2pxXVXG7WaHClick to expand...
