220
Photo Editing for Beginners - [A Guide]
  1. Venky61
    OnePlus TV Expert Community Expert Nov 30, 2018
    Venky61 , Nov 30, 2018 :
    Very well explained guide. Totally projects the essence of Post Processing. Loved it.
    I just want to add one tip for the guide about keeping a check on the color setting of the screen,on which the picture is captured and edited. Several times it happens that the night mode or some other mode of the screen is ON and the user assumes it to be the true color of the image and edits based on that. :)
    #61
    Jalex_h, Bouncer71, otto2 and 2 others like this.
  2. NeVeR_SeTTLe
    The Lab - OnePlus 6 Reviewer Nov 30, 2018
    NeVeR_SeTTLe , Nov 30, 2018 :
    Very good tip :) Thanks for sharing
    #62
    Bouncer71, TibiTibi, otto2 and 3 others like this.
  3. rdb06
    Froyo Nov 30, 2018
    rdb06 , Nov 30, 2018 :
    I am not able to take wonderful pic with my 6t in pro mood like these.
    pls teach me...
    a) how to control histogram
    b) what should be iso value, exposure time, white balance others in
    1) high light
    2) at sunset
    3) low light
    4)full night
    pls pls pls , help me
    #63
  4. NeVeR_SeTTLe
    I went over it in my Part I. Read it. :) Take my RAW file and follow my instructions and then take the same RAW file and experiment. ;)
    If you have any questions after that I'll be glad to answer them
    #64
  5. Deactivated User
    Nov 30, 2018
    #65
    Jalex_h, rdb06, Shivang Joshi and 2 others like this.
  6. hotsauce
    Lollipop Nov 30, 2018
    hotsauce , Nov 30, 2018 :
    Most landscape photographer expose to the left because its much easier to recover details from the shadows than to recover from blowned out hightlights. But that is also true for general photography. An under exposed picture have a greater chance of correction than an overexposed one.
    Just look at this pic and how much details you can recover from the shadow. (edited using Snapseed for Android)
    #66
  7. TibiTibi
    Photography Expert Community Expert Nov 30, 2018
    TibiTibi , Nov 30, 2018 :
    My words, I also mostly go under/left with the exposure.
    #67
  8. NeVeR_SeTTLe
    The Lab - OnePlus 6 Reviewer Dec 1, 2018
    NeVeR_SeTTLe , Dec 1, 2018 :
    Depends on the scene. At night time, mostly you expose to the right to get the picture much brighter. As I posted in my example. In the day light, well...that's a different story. Landscape photographys approach is different. I tend to expose to the right to get much out of the shadows and to reduce noise. Everybody's approach is different.
    With your sunset picture you want to expose to the left because you want that sun to look good while the other parts are going to be underexposed which in turn you can pull up the shadows to bring everything that is dark, brighter.
    #68
    Jalex_h, Shivang Joshi and Bouncer71 like this.
  9. kaphlerisi
    Gingerbread Dec 2, 2018
    #69
  10. NeVeR_SeTTLe
    The Lab - OnePlus 6 Reviewer Dec 2, 2018
    #70
    Shivang Joshi likes this.
  11. kaphlerisi
    #71
    NeVeR_SeTTLe likes this.
  12. NeVeR_SeTTLe
    #72
  13. rdb06
    Froyo Dec 2, 2018
    rdb06 , Dec 2, 2018 :
    so educative, thanks a lot, I Will try...
    #73
  14. kaphlerisi
    kaphlerisi , Dec 2, 2018 :
    thanks!
    I too normally use pro mode when the lighting is unfavorable and want clear view of something unclear in normal auto mode!
    Hope the lightroom functionality you mentioned is of Android version, will try next time and bookmarked your post! will read next time as well later,.
    In fact I googled much on photo composition rules and pro mode tricks, these all mentioned in one single text is very good for revision.
    thanks for the long list in simple language.
    will try editing raw pictures next time to try to get better results. this I've not done till now.
    thanks again for the post!
    ONE QUESTION: is there anything that blends two pictures taken of the same scene from exactly same viewpoint? I want to blend them to get hdr effects actually.
    e.g. sunset scene : one picture where sun is clear+ another picture where rest scenery is clear= both sun and scenery clear?
    #74
  15. rdb06
    Froyo Dec 2, 2018
    what u suggest to take better photos??
    one plus default camera app or Gcamport
    if Gcam is better then,
    pls give me the update gcam (which I Will install)
    model OnePlus 6T
    9.0.6
    #75
  16. Deactivated User
    Dec 2, 2018
    #76
  17. kaphlerisi
    phone hdr preset gives limited functionality.
    switching back to pc for every editing is boring and time consuming thing.
    #77
  18. NeVeR_SeTTLe
    NeVeR_SeTTLe , Dec 2, 2018 :
    Photoshop
    #78
  19. Deactivated User
    Dec 2, 2018
    #79
    OnePlus________8 likes this.
  20. kaphlerisi
    yeah! I have higher expectations. thanks
    #80
