[Submitted] picture in picture doesn't work with gesture navigation
  1. Ghiacciolo
    Cupcake May 29, 2020
    Ghiacciolo , May 29, 2020 :
    if gesture navigation is activated, picture in picture screen is invisible.
    when you try to activate it using gestures to back home or to open recent apps (swipe up or swipe up and hold), PiP screen is invisible. you don't know where is it and the only way to make it visible is tap all over the screen. if you find it, it will be visible again.
    I have tried both with YouTube and Twitch. same problem.
    no problem with navigation bar instead of gestures
