3
Discussion Picture quality
  1. U1522143767342
    Cupcake Mar 27, 2018
    U1522143767342 , Mar 27, 2018 :
    In my case the picture quality is amazingly great on my one plus 3t especially since I know how to use the pro mode take a look
    pvitale likes this.
  2. rw0584
    Froyo Apr 26, 2018
    rw0584 , Apr 26, 2018 :
    picture quality is obviously something that can be measured, but to be honest it also has a lot to do with perception. I am satisfied with my results, that's all I can say...
  3. logonbinit
    Cupcake Apr 29, 2018
  4. AussieOnePlusUser
    Ice Cream Sandwich Apr 29, 2018
  5. the_o2
    OnePlus 9 Series Expert Community Expert Apr 29, 2018
  6. Suraj.S.K
    Eclair Apr 29, 2018
    Suraj.S.K , Apr 29, 2018 :
    there is no issue with Oreo because the problem was in Android nougat too, the camera itself is of bad quality or OnePlus used bad quality Sony imx... cameras on next production batches of oneplus5. this is the only reason I could think of because professional photographer n Youtubers praised the OnePlus 5 camera and there are some OnePlus 5 user who claims they don't have any issues with their oneplus5 camera.OnePlus 5 was released in July 2017 they had enough time to release software patches for camera improvement. i would have enjoyed using my 1+5 and lived with it if these ******* did not hyped about OnePlus 5 camera because of the hype they raised my expectations and now I am even pissed off while using my phone.new update causing lagg ,phone heatsup a lot when charging, sometimes app crashes, Bluetooth aptx n aptx hd codec does not work properly with my aptx hd wireless headphones n also checked with friends Samsung aptx headphones same problem. OnePlus will never let u settle...
  7. Rajesh Calicut
    Donut May 14, 2018
    Rajesh Calicut , May 14, 2018 :
    Perfect response for over smartness. I also had same doubt and this question and the response in this thread only came into search result. Thanks.
  8. varun1998sai
    Cupcake Sep 8, 2018
    varun1998sai , Sep 8, 2018 :
    im getting worst panorama pics in oneplus6...can oneplus make an update over this issue??
    script likes this.
  9. G_Nader_Kabir_vfEP
    Froyo Oct 9, 2018
    G_Nader_Kabir_vfEP , Oct 9, 2018 :
    I buy a phone OnePlus 6 two weeks ago!
    Please fixed problems camera oneplus 6
    very have noise photos and video?
    quality photos and videos very poor? Don't have details!
    This said, the lack of a longer focal length for the secondary camera is a drawback for portrait mode, as a short focal length is not always the easiest to use and can cause perspective distortion.
    Other potential drawbacks revealed during extensive testing included noise in areas of uniform color, such as blue skies, strong flare, and occasional ghosting in some outdoor scenes. However, none of these are particularly concerning.
    Our OnePlus 6 test shot at 100 lux is a touch cleaner than the iPhone X’s, but not quite as smooth as the Samsung Galaxy S9 Plus’s. There is a little more visible noise at 20 lux, but overall, the approach to noise reduction is the same as in brighter light.
    Flash
    However, some luminancenoise is visible upon inspection and texture can be on the low side.
    The OnePlus 6’s Video performance isn’t quite at the level of its Photo capabilities, but it is comparable to the Apple iPhone X , even if it’s a little behind the Samsung Galaxy S9 Plus and the Google Pixel 2 used in our photo comparisons. Autofocus isn't fast even in changing lighting conditions; it has smooth tracking capabilities in outdoor and low-light conditions; and stabilization is quite efficient. Negatives are few for video capture, but nonetheless include low detail preservation in the majority of lighting conditions, particularly in low light; but even in bright light, images show quite high levels of ringing from a combination of over-sharpening and other processing steps. There is also a slight loss of sharpness caused by exposure times that are too long.
    Cons
    Noise is visible in uniform areas
    Pink cast is often visible outdoors
    Fine details sometimes lost in darkest and brightest areas
    Occasional blur inaccuracies in bokeh model
    Cons
    Loss of detail in various lighting conditions
    Strong ringing and over-sharpening
    Visible differences in sharpness between frame
  10. F1534353641876
    Eclair Oct 10, 2018
    F1534353641876 , Oct 10, 2018 :
    y oneplus 6 pics tends to give softer and over saturated images.... rather more sharpness and contrast can give some excellent results.....
    soROCKin88 likes this.
  11. C1543331009005
    Cupcake Nov 27, 2018
  12. hotsauce
    Lollipop Nov 27, 2018
    hotsauce , Nov 27, 2018 :
    post some examples
  13. C1543331009005
  14. hotsauce
    "actual color" is very relative. Whitr balance and external light source can affect this. Without you posting an example of a picture with the settings people vannot determind if this is camera issue or user issue.
    script likes this.
  15. C1543331009005
  16. hotsauce
    Ok this is normal, it's because you're taking a picture under warm white light. To fix this you need to go into pro mode and turn your WB/White balance down to a cooler temperature. Think around 3000K. This is just a function of auto white balance on your camera. You correct in pro mode or correct afterward in editing software like Snapseed.
    script likes this.
  17. script
    Moderator Moderator Nov 28, 2018
    script , Nov 28, 2018 :
    Thank you for your help.
    hotsauce likes this.
  18. pvitale
    Froyo Dec 16, 2018
    pvitale , Dec 16, 2018 :
    6T night photo pic above. Gave up new note to make switch to 6T. lost a few features but gained some as well. Liking this phone so far.
  19. 01baftb
    Gingerbread Mar 1, 2019
  20. script
    Moderator Moderator Mar 1, 2019
    script , Mar 1, 2019 :
    Please have a look at these pics, taken under good conditions.
    Shot on OnePlus February
    Ofc I see pics of bad quality, and some of them suffer from post processing. But, many photographers can take very good pictures with the OnePlus phones. So, it's simply possible to take good pics.
    Also, not 90 % of the users have problems, just 90% of the users in your thread. That's a big difference.
    Script
    Baymax likes this.
