PIN Concern.
  1. su23resh
    Cupcake Jan 22, 2020
    su23resh , Jan 22, 2020 :
    Hello People.
    It's been 3 months approximately I am using OnePlus 7T and I noticed one thing that my phone sometimes asks me to enter Phone PIN to unlock the phone.
    Is it because my phone restarts automatically?
    I am not aware what exactly is the issue.
    Kindly advise me on this.
    Thank you.
  2. Sheppards
    Honeycomb Jan 22, 2020
    Sheppards , Jan 22, 2020 :
    This is no issue.
    every once in a while it'll ask for the PIN. If you read the message on the screen it will tell you why
    Liehjan, su23resh and colaboy like this.
  3. Ramu Yandra
    Donut Jan 23, 2020
    Ramu Yandra , via OnePlus 7T , Jan 23, 2020 :
    for security purposes it asks for pin or pattern sometimes nothing to worry about
    additionally it is for to remember your password.. not to forget
    su23resh likes this.
  4. ngydat
    KitKat Jan 23, 2020
    ngydat , Jan 23, 2020 :
    Once in a while, your phone will ask you to enter your pin code or to draw your pattern in order to remember it.
  5. Cosmos_NT
    Jelly Bean Jan 23, 2020
    Cosmos_NT , via OnePlus 7T , Jan 23, 2020 :
    One more fact : If you are using Lockdown mode once a week ( or maybe in couple of weeks), then the device won't randomly ask for pin/ password etc. It is like there is a timer ( assuming idk if there is any in real) which automatically when runs out, the device triggers manual confirmation overriding biometric authentication. But as I explained if you happen to be using the Lockdown mode, the timer gets a reset and this way it doesn't randomly ask for the pin or password...
    su23resh, colaboy and ngydat like this.
  6. ngydat
    KitKat Jan 23, 2020
    Good to know :)
    su23resh and Cosmos_NT like this.
  7. su23resh
    Cupcake Jan 23, 2020
    su23resh , Jan 23, 2020 :
    Thank you for your reply.
  8. su23resh
  9. su23resh
    Cosmos_NT likes this.
  10. su23resh
  11. Cosmos_NT
    Jelly Bean Jan 24, 2020
    Cosmos_NT , via OnePlus 7T , Jan 24, 2020 :
    su23resh
    You're welcome and if you didn't knew here is one more thing you should know...
    If you have multiple users to reach back, use +Quote button (in place of reply) for every user you want to say something and then in the comment (message like icon) button ( which will appear on the bottom when you quote) add all of them.
    You can quote one person and then write something for him/her above or below the quote if you wish to do so (just don't mess with quote tags between square brackets , however you can change the content between those tags if you wish, see the example I have given in the end) and then you can add next one and so on
    Example:
    su23resh
    Thank you for letting me know !?!!!.​
