Pin de carga
  1. D1522979193762 Donut Jun 13, 2019 at 1:46 AM
    D1522979193762, Jun 13, 2019 at 1:46 AM :
    hola, tengo un problema y es que yo tengo el cargador original del oneplus 3t y en mi nuevo oneplus 5t no hace buena conexion el cable, tengo q meterlo muy adentro y dejar quito xq sino no hace conexion y con otros dos cables de un moto z play tampoco pero con un adaptador q tengo de micro usb a usb tipo c anda re bien. queria saber si es q el pin de carga anda mal o es q el pin de carga es distinto
  2. pablofg1978 Spanish POC Assistant Head Moderator Jun 13, 2019 at 2:23 AM
    pablofg1978, Jun 13, 2019 at 2:23 AM :
    Has probado de limpiar el puerto de carga?
  3. D1522979193762 Donut Jun 13, 2019 at 2:38 AM
  4. John Wagner Cupcake Jun 13, 2019 at 2:45 AM
    John Wagner, Jun 13, 2019 at 2:45 AM :
    Please note that the "micro usb to usb type c" adapter does not support Dash Charge I do suggest you to get a OEM Dash Cable or a Type A to Type C Cable which will only support Fast Charging.
    If I were you I would ditch the cheap adapter and get a dash cable less problems down the road because those adapters can may fail and damage your device.
