PIN LOCK
  1. Akshaypatil95
    Cupcake Feb 8, 2019
    Akshaypatil95 , Feb 8, 2019 :
    how should i unlock my phone its not accept my PIN which i set for the lock screen ...
    This lock screen different from actual lock which appeared normally its ask for PIN not password and i do not set any other PIN
  2. Liehjan
    Lollipop Feb 8, 2019
    Liehjan , Feb 8, 2019 :
    The phone does not ask for a random PIN, if it wants you to insert a PIN.. It's one that you have chosen when setting up your device for first time:)
  3. Akshaypatil95
    Cupcake Feb 8, 2019
    what if accidentally i set and I don't know now ?
    how can i unlock now ?
  4. Liehjan
    That means you had to accidentally put it in twice, as when you setup a PIN you need to input it twice... What you can do is to boot into recovery and wipe everything (but that means you will loose everything on your device) ... Or try to remember the PIN, that's the best option
    toastytoast1234 likes this.
