4
Pinch to zoom is not working properly..
  1. amartens181
    KitKat Sep 14, 2014
  2. p4r4d0x
    Ice Cream Sandwich Sep 14, 2014
    p4r4d0x , Sep 14, 2014 :
    I had similar issue on google maps. only once.Restarted phone and everything went back to normal.
  3. bogusm
    Gingerbread Sep 14, 2014
    bogusm , Sep 14, 2014 :
    The problem is not related to the browser. The pinch and zoom issue is OS or Hardware. I have this issue in Maps, Chrome, Gallery, Camera, Adobe, and other apps. A restart is not THE solution.
  4. Cynosural
    Donut Sep 15, 2014
  5. Malicaly
    Gingerbread Sep 15, 2014
  6. tony1208
    Ice Cream Sandwich Sep 15, 2014
    tony1208 , Sep 15, 2014 :
    Dam mine is screwy as well..... factory reset the only solution as of now?
  7. na1564
    Donut Sep 15, 2014
  8. prejane
    Cupcake Sep 15, 2014
  9. Morttem
  10. lllzh
    lllzh , Sep 15, 2014 :
    My wife's OPO had the same problem, then a simple reboot solved it... apparently she had not reboot OPO since 33R update.
  11. Rajandmk
    Rajandmk , Sep 15, 2014 :
    Hello everyone, I was having the same problem, so called multi-touch issues, I fixed it just by changing the theme to 'Holo' (you can just only update 'styles' and leave the rest) and then rebooting the phone. Trust me, try it once and you'll be surprised to see that working. You can test your multitouch using YAMTT. Best of luck..
  12. pitxialonso
    Eclair Sep 17, 2014
  13. medicopter
    Eclair Sep 18, 2014
  14. georgywhitcher
    Gingerbread Sep 18, 2014
  15. BLNKN
    Froyo Sep 18, 2014
  16. leemartin
    Lollipop Sep 18, 2014
    leemartin , Sep 18, 2014 :
    I've not experienced this, but I`m sticking to the OTA updates as frustrating as the waits are....
  17. magicblack
    Ice Cream Sandwich Sep 18, 2014
    magicblack , Sep 18, 2014 :
    The problems of multi-touch are still here! The multi-touch didn't work until I did a reboot. CM 11 nightly 15/09 with the latest fixes included.
  18. rocks
    Cupcake Sep 19, 2014
    rocks , Sep 19, 2014 :
    Just seen this thread. I got my OPO last week ad have been experiencing exactly the same issue across all apps ( chrome, gallery, maps etc). I came from using an old S3 which had superb pinch to zoom capabilities amongst other gestures.
    Everything else about the phone I love so far but would really love to find a solution to this annoying problem? (stock CyanogenMod with no customisations)
  19. echoestime
    Gingerbread Sep 19, 2014
    echoestime , Sep 19, 2014 :
    It's a known bug and it should be fixed in the next OTA.
    For now, rebooting the phone should fix it;)
  20. Madmanden
    Donut Sep 20, 2014
