7
Pink Vertical line on OnePlus 8t Display
  1. InduwaraG
    Froyo Apr 20, 2022
  2. imarul
    Cupcake Apr 20, 2022
  3. Tobikage
    General Support Expert Award 2021 Apr 20, 2022
    InduwaraG likes this.
  4. zivamyangel
    zivamyangel , via OnePlus 8T , Apr 20, 2022 :
    My mobile(1+8t)The green line came up while using It's only been 15 months since I bought my mobile. Did not fall down or fall into the water, I use it very carefully
  5. InduwaraG
    Froyo Apr 21, 2022
    InduwaraG , via OnePlus 8T , Apr 21, 2022 :
    Same. Mine also 15 months old 😭 and the warranty period was 12 months so no good news for me.
  6. InduwaraG
    Froyo Apr 21, 2022
  7. Wishnu_Mohan
    Cupcake Apr 21, 2022
  8. InduwaraG
    Froyo Apr 22, 2022
  9. Tobikage
    General Support Expert Award 2021 Apr 22, 2022
    Tobikage , Apr 22, 2022 :
    Why would that be a factor anyway ?
  10. InduwaraG
    Froyo Apr 22, 2022
    InduwaraG , via OnePlus 8T , Apr 22, 2022 :
    Nope it would not but it's too tight so if the build quality of OnePlus 8T phones are not great as we expected there could be a problem. At this point when you think about OnePlus just expect disappointment , then you can never really be disappointed.
    T1630956692714 likes this.
  11. Tobikage
    I really doubt even the tightest of cases would cause it...theres enough clearance even if it's a tight fit.
    Pressure being applied to the display / bezel is a possibility......While putting on or removing the cases.
    Again comes down to the phones construction.
    T1630956692714 and InduwaraG like this.
  12. InduwaraG
    Froyo Apr 22, 2022
    Yes sir well said it all goes to OnePlus and their build quality.
  13. ashruuk
    Cupcake Apr 24, 2022
    ashruuk , Apr 24, 2022 :
    Same here... Pink line after updating to 12.... I think new phones have no enough build quility... Because I started using oneplus2. It is still working without any issues. And I bought OnePlus 3 and 3t and have no issues. Then i bought OnePlus 6t.. some issues like volume button not working after 1 year.. now I bought one plus 8t. Got a vertical pink line after 1.3y. Went to OnePlus authorised service center. They said it is a hardware problem. One of them told me 'did it came after updating OS 12'. They said to use this with line or pay 14k..😡🤬 this will be my last OnePlus phone.... Planning to change to different brand. Will recommend others not to buy OnePlus phones
    deepsay, T1630956692714 and InduwaraG like this.
  14. T1630956692714
    Cupcake Apr 27, 2022
    T1630956692714 , via OnePlus 8T , Apr 27, 2022 :
    I too have a OnePlus 8t and my display has also got the same way with many lines now. I haven't dropped my phone evenbone time. Really sad to see a brand so bad with their service. I have seen a lot of my friends with same issue. They also haven't dropped the phone. OnePlus is going really shit now....!
    Kartik shetty, ashruuk and InduwaraG like this.
  15. Arunkumar7R
    Cupcake May 4, 2022
    Arunkumar7R , via OnePlus 8T , May 4, 2022 :
    Same damn issue. I was casually using this morning and a pink line popped out of nowhere. My phone never fell and is always with a protection case and screen guard. Is this something related to hardware? Do I need to change the screen?
  16. W1602853084346
    Cupcake May 4, 2022
    W1602853084346 , via OnePlus 8T , May 4, 2022 :
    I am also facing green lines issues on 8t and the phone didn't even fall, also the worst part is my phone is out of warranty.
    This is why we should not have to trust on china products
  17. InduwaraG
    Froyo May 4, 2022
    InduwaraG , via OnePlus 8T , May 4, 2022 :
    Yes, you have to change the screen otherwise use it with the pink vertical line at least those are the options that my seller gave me.
    Arunkumar7R likes this.
  18. Califormula
    Donut May 4, 2022
    Califormula , via OnePlus 8T , May 4, 2022 :
    jesus! it seems i'm not the only one. this happened on my device just yesterday. i'm not even sure what caused the line to appear. i never dropped it nor pressed hard on it smh
    #38
  19. cfbielok
    Eclair May 6, 2022
    cfbielok , via OnePlus 8T , May 6, 2022 :
    This problem has been going on since at least 2017 if not earlier. Strange it takes so long to fix.
    #39
    InduwaraG and Califormula like this.
  20. Kartik shetty
    Donut May 12, 2022
    Kartik shetty , via OnePlus 8T , May 12, 2022 :
    Same issue with mine as well
    #40
