Pixel Experience problems
  1. arashaus
    Donut Jan 26, 2018
    arashaus , Jan 26, 2018 :
    Hey I am getting an awful SOT on this Rom(installed it yesterday) and it is charging super fast, as if it wasn't charging the whole battery or maybe it doesn't recognize the battery capacity, can someone help me.
  2. thakurayush0497
    Gingerbread Jan 26, 2018
    thakurayush0497 , Jan 26, 2018 :
    pixel experience rom does have battery issues....u should have carefully gone through reviews before installing the rom.
  3. idkwhoiam322
    Nougat Jan 26, 2018
    idkwhoiam322 , Jan 26, 2018 :
    Tell in their thread? What's the point in posting here, no dev will fix it if you tell anything here/
  4. arashaus
    Donut Jan 26, 2018
    Well just seeing if someone else had a problem like this and if it was something I could easily fix
  5. saahill
    saahill , Jan 26, 2018 :
    Use Blue Bolt kernel with the ROM, I'm getting 4 hrs SOT.. 3-3.5 HRS SOT is normal in all oreo ROMS
    And greenify helps me too
  6. filipebatt
    Gingerbread May 10, 2018
    filipebatt , May 10, 2018 :
    you lost me in Greenify... Battery saving apps only use more battery.
  7. filipebatt
    i'm using the same rom, without any problems. Flash the latest OB and then flash the Pixel Experience. And Wipe everything except internal prior to installation, and after the installation wipe cache.
