play store download problem
  1. THIHASNI
    Eclair Jan 31, 2017
    THIHASNI , Jan 31, 2017 :
    after update in op3 play store download problem occurs.. how to rectify...anybody knows.
  2. Rupeshrg
    Eclair Jan 31, 2017
    Rupeshrg , Jan 31, 2017 :
    Oneplus has provided a fix in the form of Oxygen Os 4.0.2. Try installing that.
  3. G_Ryan_Deshaies_eFBQ
    Eclair Jan 31, 2017
  4. anoopa0505
    Cupcake Jan 31, 2017
    anoopa0505 , Jan 31, 2017 :
    Nope... Mine is oxygen OS 4.0.2...am facing the same issue... Can not download any app using the data connection...while with wifi everything is fine...only play store has this issue...I just found out that if u r using the data connection in roaming u can not download any app from playstore...only not working with play store... Try to use home network data connection to download from play store ...it will work...it is the issue with the new update....this is the only thing I found error with the new update....if anybody knows how to fix this... Need some help here... Tq
  5. selvakumarp
    Cupcake Feb 5, 2017
    selvakumarp , Feb 5, 2017 :
    if u want download any app at roaming data best go for second party play store like 9app. it's very good download very easy.
