Play Store draining battery
  1. yawarkhalid
    Honeycomb Oct 30, 2018
    yawarkhalid , Oct 30, 2018 :
    Hi. My play services is hogging too much battery. I tried clearing play services data and cache. Also tried to uninstall updates of play services but the phone doesn't allow me to do that. Advice?
    fyi: already tried searching the forum.
  2. Prcko
    KitKat Oct 30, 2018
    Prcko , Oct 30, 2018 :
    Check this and next time use search before you open new thread this
  3. yawarkhalid
    Unfortunately as per that solution, I'm supposed to uninstall Plays Store Updates which I am not able to do. Got any other thread to quote regarding that problem that can help?
  4. Deactivated User
    Oct 30, 2018
  5. Prcko
    KitKat Oct 30, 2018
    This solution works. If you don't believe you can use search button or Google
  6. yawarkhalid
    Every app uses Google Play Services as the location service is given through Play Services in Pie. I've tried that though btw.
  7. Deactivated User
    Oct 30, 2018
    yawarkhalid likes this.
  8. yawarkhalid
    Ohh buddy im sure it does. Not denying that. Just saying my problem is a little different than what's on that thread. My problem is that I am unable to execute that solution as I can't uninstall Play services updates. Would appreciate searching and quoting another thread for that. Peace. [e]270c[/e]️
  9. yawarkhalid
  10. Prcko
    KitKat Oct 30, 2018
    Do you read solution? Uninstall updates
  11. yawarkhalid
    Do you read what im saying?
    Unable to Uninstall updates!!
  12. Prcko
    KitKat Oct 30, 2018
    How do you uninstall updates?
  13. yawarkhalid
    Just let it go. I'd appreciate help from someone else. :)
