Play store Problem....
  1. Atiqur99
    Cupcake Sep 14, 2018
    Atiqur99 , Sep 14, 2018 :
    Facing problem to install or Update any apps from #PlayStore
    When Start Update or Install any apps then the net connection go down....
    After waiting and waiting, not able to update or install....
  2. Jacek Pecka
    Ice Cream Sandwich Sep 14, 2018
  3. the_o2
    User of the Year 2018 Sep 14, 2018
    the_o2 , Sep 14, 2018 :
    Let me guess, Nothing :tearsofjoy:
  4. Atiqur99
    I try so many steps to solve.....bt it's not working....
    Clearing tha cache file, clearing data of Playstore....
    Bt it's not working.... Unable to update or install any apps from playstore..... When its show downloading or Updating the connection goes down...
  5. Jacek Pecka
    Jacek Pecka , Sep 14, 2018 :
    Is AppStore has rights to use data?
    L1518294941536 likes this.
  6. ratansuthar00
    Eclair Sep 14, 2018
    ratansuthar00 , Sep 14, 2018 :
    Hi, Look like You are using a 4g data active connection, Just in case did you tried these things such as 1) Mobile data off and on 2) Reset the default APNs settings 3) Check if downloading is working on a wifi connection.
  7. Atiqur99
  8. Atiqur99
    Ok
  9. Atiqur99
    Take All those steps....
    Bt no solution....
  10. Atiqur99
    Tnx All for suggestions....
    At last able to solve the problem....
    It was happening because of two apps...
    After Uninstalling them playstore start to installing...
