Play Store Problem
  1. Mahesh_Ahir Cupcake Dec 7, 2018
    Mahesh_Ahir, Dec 7, 2018 :
    Since Last Two Days I Can't Open Google Play Store And YouTube. When I Open It Show Only Blank Display.
  2. Maverick2.0 Jelly Bean Dec 7, 2018
  3. Mahesh_Ahir Cupcake Dec 7, 2018
  4. Mahesh_Ahir Cupcake Dec 7, 2018
    Now I Removed My Account From Mobile And Try To ReLogin But I Can't Login.
  5. Shield98 Honeycomb Dec 7, 2018
    Shield98, Dec 7, 2018 :
    Mahesh_Ahir
    Post it and also explain how this issue started
    Are you also facing issue in other Google app like Gmail, Calender etc..?
  6. Mahesh_Ahir Cupcake Dec 7, 2018
    Yes All Google Related App Doesn't Work.
  7. Shield98 Honeycomb Dec 7, 2018
    This issue general occurs in slow internet speed
    I have also faced when My Internet speed was slow
    Try using a faster network.
  8. Mahesh_Ahir Cupcake Dec 7, 2018
    i also try in high speed wifi but nothing happened.
  9. Akhshay Srinivasan Marshmallow Dec 7, 2018
    Akhshay Srinivasan, Dec 7, 2018 :
    > Check whether you're updated with play store version 12.7.23.
    > If you're running with the latest version of play store, download speed test app from your laptop and check your WiFi speed test here.
    > If everything is working fine (including your Gmail or other apps), submit your bug here.
  10. Mahesh_Ahir Cupcake Dec 10, 2018
    Mahesh_Ahir, Dec 10, 2018 :
    i try all
  11. tas1 Eclair Dec 10, 2018
  12. Mahesh_Ahir Cupcake Dec 10, 2018
  13. Shield98 Honeycomb Dec 10, 2018
    Shield98, Dec 10, 2018 :
    Uninstall the update of GOOGLE PLAY SERVICE and Google Play Store.
    and Reboot your device.
    Then login
    If this doesn't help then Your last solution would be factory rest your device.
