12
play store
  1. Bakflow
    Cupcake Nov 16, 2018
    Bakflow , Nov 16, 2018 :
    I'm having the same issue. Notifications are on for Play Store but they are not showing when there is an update, a download is happening, or when an app just completed installation. Deleting cache and data for Play Store in settings only works temporarily. I didn't have any issues on update 9.0.4.
    #41
  2. M1541165619337
    Eclair Nov 16, 2018
    #42
  3. Nikhilesh750
    Honeycomb Nov 16, 2018
    Nikhilesh750 , Nov 16, 2018 :
    I've found a workaround, check if this works or not.
    Here solution for this weird bug but before that do a clear storage for playstore just in case then
    1. Go to Settings, Apps & notifications, see all apps, touch 3 dot, Show System, find Android Setup(i had 2 android setup one can't be cleared and the other can be cleared) go to Storage and clear storage.
    2. Back to Settings again, search Download Manager, open Notification, click on in progress and done, set them both to "Show silently".(but i have set all 3 of them In progress, Done & Queued to 'Show silently')
    3. Reboot
    #43
  4. Nikhilesh750
    Check my comment and after that if u face problem in which updates are available and its not showing in notification bar then
    Go to playstore app info, notifications, app updates available and set it to show silently. After doing all if it still persist wipe cache.
    #44
  5. ImDolvin
    Eclair Nov 16, 2018
    #45
  6. ImDolvin
    Eclair Nov 16, 2018
    #46
  7. M1541165619337
    Eclair Nov 17, 2018
    M1541165619337 , Nov 17, 2018 :
    stilll not works
    #47
  8. truepreet
    Cupcake Nov 17, 2018
    #48
  9. J1541574970745
    #49
  10. Nikhilesh750
    Honeycomb Nov 17, 2018
    #50
  11. dickymastelero
    Eclair Nov 17, 2018
    dickymastelero , Nov 17, 2018 :
    It helps to reboot after any big updates especially in multiple apps to initialize apps properly. And also check your update preference maybe it's UPDATE ON WI-FI ONLY.
    #51
  12. [email protected]
    [email protected] , Nov 17, 2018 :
    Guys, even I was facing this problem in the beginning. Below is what I did to resolve it once and for all. I used OnePlus Switch to transfer my data from old phone to new phone, that is what I think few apps messed it up.
    Go to Settings > Apps & Notifications > Click on See all apps
    Now besides the App Info, you'll see 3 dots in the right.
    Click on that and select "Reset App Preferences"
    Now, reboot phone and check if it works!
    Cheers!!
    Note : I was not able to resolve it even when I tried to clear data cache for google play store, framework, boot into recovery and clearing cache, etc. but the above solution worked & I don't wanted to do a factory reset just for this.
    #52
  13. manvaz27
    Eclair Nov 18, 2018
    manvaz27 , Nov 18, 2018 :
    Guys think i got the last "Solution" to this problem, I had to do a factory reset by a bad APK that I installed and forced me to to this, I approached the moment to test installing in lots of 10 apps and trying if still play store was working to see if was problem with any app installed, after my 113 apps I got the ANSWER:
    PROBLEM IS WITH NETWORK NOT WITH ANY APP OR CACHE OR DATA, IF YOU PUSH TO INSTALL SOME APP AND DONT LET YOU OR TRY TO UPDATE JUST TO THE FOLLOWING
    PUSH INSTALL OR UPDATE, IF DOESNT START JUST TURN OFF THE WIFI ON YOUR PHONE AND TURN IT ON AGAIN, IN SOME SECONDS WILL START TO DOWNLOAD OR UPDATE.
    -PLAY STORE VERSION 12.5.15
    Hope it works for all
    #53
  14. aktiwa
    Cupcake Nov 18, 2018
    aktiwa , Nov 18, 2018 :
    Got my phone today.
    Facing Same problem . it works most of the time. I can download a few apps, then it just starts to get stuck in downloading. I restart the phone, then it works for 3 or 4 apps then freezes again.
    Also if I clear the memory by forcing all apps to close and try to download app again then it works for some apps and then again gets stuck for other apps.
    #54
    Froyo Nov 18, 2018
    aditya.jpeg , Nov 18, 2018 :
    I reported this problem using logs, the development team replied by saying it'll be fixed in the next update
    #55
    manvaz27, Bakflow and aktiwa like this.
  16. Y1543314342393
    Cupcake Dec 3, 2018
  17. josh6701
    Eclair Dec 5, 2018
    josh6701 , Dec 5, 2018 :
    I had this on my 6T and tried a few hours later and it was fine, haven't faced the issue since.
    #57
  18. O1541305616324
    Cupcake Dec 8, 2018
    O1541305616324 , Dec 8, 2018 :
    still facing issue?
    #58
    Froyo Dec 8, 2018
    #59
  20. O1541305616324
    Cupcake Dec 8, 2018
    #60
