playstore app update problem
  1. JasonMR
    Lollipop Dec 16, 2016
    JasonMR , Dec 16, 2016 :
    I dirty flashed and don't have this issue.
    Sun90 likes this.
  2. mak0864
    Honeycomb Dec 16, 2016
  3. Vinil1981
    Cupcake Dec 16, 2016
  4. blackchris
    Cupcake Dec 17, 2016
  5. akks
    KitKat Dec 17, 2016
    akks , Dec 17, 2016 :
    Ok, then probably those from India only.
    Anyways, I don't have this issue always.. Sometimes app gets updated using mobile data also..
  6. Vellblues
    Gingerbread Dec 17, 2016
    Vellblues , Dec 17, 2016 :
    That is because you have data restrictions in the roaming configuration, or that your operator restricts you
  7. Vellblues
    Please reset your Google services. Delete cache and data, restart the phone normally and enter again in the Play and you again login
  8. Vellblues
  9. Vellblues
  10. sandesh2007
    Eclair Dec 17, 2016
    sandesh2007 , Dec 17, 2016 :
    Factory reset will solve this issue.
    Clearing data and cache was not solving the issue
  11. Berg P.
    OxygenOS Team Staff Member Dec 22, 2016
    Berg P. , Dec 22, 2016 :
    are you using jio?
  12. chinna2ali
    Froyo Dec 22, 2016
  13. G_SHAHERYAR_AHMED_TQxR
    Cupcake Dec 22, 2016
  14. Berg P.
    OxygenOS Team Staff Member Dec 24, 2016
    Berg P. , Dec 24, 2016 :
    sir, i noticed you enable data roaming when cellular network cant download happening.
    could you have a try if disable data roaming and restart the phone would fix data network cant downloading problem?
  15. saikiran4ever
    Jelly Bean Dec 29, 2016
    saikiran4ever , Dec 29, 2016 :
    Resetting app preferences worked for me...
    i.e. Settings - Apps- 3 Dots- Reset App Preferences
    seetharaman likes this.
  16. seetharaman
    Cupcake Jan 8, 2017
    seetharaman , Jan 8, 2017 :
    It started working for me as well after the app preference reset
    saikiran4ever likes this.
  17. Sanket_Trivedi
    Cupcake Feb 6, 2017
    Sanket_Trivedi , Feb 6, 2017 :
    i am not able to update or download application in my OP3t after android update through data connection. it works well on WiFi
  18. ghostofcain
    Marshmallow Feb 6, 2017
    ghostofcain , Feb 6, 2017 :
    Known issue, needs a fix from google, bigger issue is your inability to post in the correct thread for your device.
    #38
  19. F_Varad_Bandishti_UrfA
    Donut Feb 6, 2017
    #39
  20. tiwariankit
    Gingerbread Feb 7, 2017
    #40
