Please do fix these issues in oxygen os 11, OnePlus Nord via OnePlus Nord
  1. keshav.aggarwal
    Cupcake Apr 8, 2021
    keshav.aggarwal , via OnePlus Nord , Apr 8, 2021 :
    1. The icons are not properly aligned in the status bar in landscape mode.
    2. After Oxygen OS 11 my phone has heating issues. It heats alot near the camera and speaker on the back and also while charging.
    3. If we use the alert slider to change the profile while our phone is locked and it's screen is off then whenever we turn the screen on even if we turn it on after a long time, the profile change bubble always shows on the right.
    4. And after Oxygen OS 11 the system is occupying 27 GB of my storage which was around 20 GB in Oxygen OS 10. Please optimize this also.
    5. When I connect my OnePlus Buds Z with my phone, sometimes my phone isn't able to detect the battery percentage of my earphones. It shows 1 percent battery but when I connect it the second time then my phone shows its real battery percentage that is 100 percent.
    PLEASE FIX ALL THESE ISSUES ASAP.
  2. Tokolozi
    Most Original Avatar Apr 8, 2021
    Tokolozi , Apr 8, 2021 :
    This is a users forum.
    Report your issues via the feedback section of the community app instead....
    KluGe, B_Wrath, Bobbie63 and 2 others like this.
  3. keshav.aggarwal
    Cupcake Apr 8, 2021
  4. Aaron2017
    Jelly Bean Apr 8, 2021
    Bobbie63 likes this.
  5. keshav.aggarwal
    Cupcake Apr 8, 2021
  6. Aaron2017
    Aaron2017 , Apr 8, 2021 :
    1 is like that if you have the music player in your notification panel, if you don't have it there, they will align as normal.
    3 is to let you know you changed the alert slider, in case you accidentally changed it without knowing for example, and therefore maybe miss calls and notifications.
    4 don't really know why that is, but it's that way for all phones updated to OS11 so i think that's normal too.
  7. Bobbie63
    Marshmallow Apr 8, 2021
    Bobbie63 , Apr 8, 2021 :
    Does the bubble keep showing? Mine turns off after two seconds or so. It doesn't show up the second time I unlock the phone.
  8. keshav.aggarwal
    Cupcake Apr 8, 2021
    If it's not aligned properly when we have the music player in the status bar then it's an issue.
    And when we change the phone's profile While the screen is off it shows the changed profile on the black screen and there is always an icon on the status bar if your phone is in vibration mode or Silent. So there is no need to show it on the right even after an hour whenever we turn on the screen.
    5 is a suggestion and a genuine problem of my phone.
  9. Bobbie63
    So 3 isn't an issue as it's a reminder you've changed the settings. Especially after unlocking your phone this is always a good thing you get reminded you've changed your profile.
  10. keshav.aggarwal
    Cupcake Apr 8, 2021
    I'm not talking about second time.
  11. Bobbie63
  12. keshav.aggarwal
    Cupcake Apr 8, 2021
    But it wasn't there in oxygen os 10 and what I think is that i it's not necessary to show after you turn the screen on after alot of time
  13. Bobbie63
    I don't know if it was or wasn't, I think it's a good addition.
  14. keshav.aggarwal
    Cupcake Apr 8, 2021
  15. Bobbie63
    Yes and I see no need to change this as it's surely been added with a purpose.
  16. keshav.aggarwal
    Cupcake Apr 8, 2021
  17. Bobbie63
    That's your opinion, good luck getting it changed. You're the first complaining about a pop up bubble that dissappears after two seconds.
    Aaron2017 likes this.
  18. keshav.aggarwal
    Cupcake Apr 8, 2021
    Good luck to you too for not considering 1st as an issue.
  19. Aaron2017
    These are things they included in OS11 or android 11 if it's an implementation made by Google, so they are not seen as issues with the OS because they designed it that way. So it seems you just don't like the changes they made, which is fine of course, not everyone likes the new design. Took me a good while to get used to as well.
    KluGe and Bobbie63 like this.
  20. keshav.aggarwal
    Cupcake Apr 8, 2021
    I agree with you that many of them are suggestions but if you read it thoroughly 1, 2 and 5 are issues that needs to be fixed asap
