PLEASE HELP!!! I BRICKED MY OPO!!! PLEASE!! :(
Thread Status:
Not open for further replies.
  1. DaxNagtegaal
    Marshmallow Apr 16, 2015
    DaxNagtegaal , Apr 16, 2015 :
    This thread has 9 pages and his problem still isn't fixed I doubt I'll be able to help if 9 pages of comments resulted in nothing
    Peanutbrain and royz0r like this.
  2. 19dolev
    Honeycomb Apr 16, 2015
    19dolev , Apr 16, 2015 :
    lol. ok....
    ok i will post now
  3. 19dolev
    on the toolkit
    Deactivated User likes this.
  4. Deactivated User
    Apr 16, 2015
  5. Deactivated User
    Apr 16, 2015
  6. Alivethereality
    Jelly Bean Apr 16, 2015
    Alivethereality , Apr 16, 2015 :
    at least there is progress
    DaxNagtegaal likes this.
  7. 19dolev
  8. DaxNagtegaal
    After 9 pages? I wouldn't call that progress, I'd call that a lost cause with a ton of frustration.
  9. bumptheposts2
    Gingerbread Apr 16, 2015
    bumptheposts2 , Apr 16, 2015 :
    Flashing AK over oxygen is a simple mistake. Simply force the phone to off like this:
    - Disconnect from PC / wall charger
    - Hold power for 10 sec
    - Power on with volume down pressed until recovery shows
    Then simple wipe all (not media, usb) and start again.
    I did the same :)
    EDIT: This will NOT WORK when plugged in a USB port... strangly but true.
  10. vannghia
    Cupcake Apr 16, 2015
    vannghia , Apr 16, 2015 :
  11. 19dolev
  12. Alivethereality
    why don't you check in the task manager if the cpu is being used by the toolkit
    if it is then its definitely not stuck
  13. francesco995
  14. 19dolev
    ok i will check
  15. Alivethereality
    its called solving the problem
    he was screaming and now he is calm and the situation is more under control
    if the toolkit is using his magical powers to do something then its differently solvable
  16. 19dolev
  17. Dilbert101
    Alivethereality likes this.
  18. 19dolev
    Ok so the toolkit isn't working, it's stuck (it requires 0% cpu) so now should i do this?^^
  19. vannghia
    No worry, pal. Have you heard
    ONEPLUS+ONE-FIX-Windows(update/fix) file? I was trying to upload the file for you to get it fix but the file is too large in order for me to upload and share it with you. what you can do is to send me your email and I could share this file with you through Google Drive.
  20. 19dolev
    for how much time?
