Please Help Me!!!!
  1. drummer79
    Froyo Nov 22, 2019
    drummer79 , Nov 22, 2019 :
    I know this topic is redundant and a lot of you don't wanna hear it but I am legit stuck in a trap! I have a 7 Pro and I need to return to the 10.0.2 stable from the Beta 6. I have completely wiped the phone memory and cache so many times and put the right zip file that is made to return me to the stable 10.0.1 in the phones main storage where it should go and it never shows up in the local upgrade section! IF YOU HAVE SOME VALUABLE ADVICE, PLEASE HELP! I AM VERY GOOD WITH ANDROID PHONES SO I CAN FOLLOW MOST ANYTHING PERTAINING TO THIS.
  2. jasemanONE
    Gingerbread Nov 23, 2019
    jasemanONE , Nov 23, 2019 :
    If you are on Beta 6 you will lose everything going back to stable...it will wipe your phone.
    If you still have the ability to do so go to the Google Play Store and install Oxygen Updater...I have used it several times on a One Plus 6 as well as the 7 Pro and it works great!
    Once you have this app installed just follow the directions to upgrade to stable from Beta.
    drummer79 likes this.
  3. drummer79 , via OnePlus Community App , Nov 23, 2019 :
    I've done all that a dozen times or more. My 7 pro is wiped clean. I cannot get the file to show up in the local update. I know to put the file in the mail device storage. Very Frustrating!
  4. jasemanONE
    What do you mean by "mail device storage"??? Sorry but that makes no sense at all. When you say the phone is wiped clean does it even have an operating system installed and working on it? If not, then you need to search for instructions on using the OnePlus MSM Tool which is designed to restore a bricked phone. Once you have a working version of Android on the phone THEN install Oxygen Updater and upgrade to 10.0.2. XDA Developers is one forum that can help you with the MSM Tool.
  5. drummer79
    Froyo Nov 23, 2019
    drummer79 , Nov 23, 2019 :
    sorry "mail device storage was a typo. I meant Main Phone storage. Or Root Storage I believe it's called.
  6. B_Wrath
    Marshmallow Nov 23, 2019
    B_Wrath , Nov 23, 2019 :
    Post a screenshot of the file name.
  7. drummer79
    Froyo Nov 23, 2019
    phone is not bricked. I did a factory reset and cache wipe. it is working as though it would out of the box. I think the problem is that is is wiped but always boots back up with the Beta 5 on it. I cannot get it back to the SAFE 10.0.2
  8. drummer79
    Froyo Nov 23, 2019
    The file is shown here that I am sure is the one I need. but it won't show up in the Local Upgrade. I have a 7 Pro and it's currently hung on Beta 5.
  9. B_Wrath
  10. drummer79
    Froyo Nov 23, 2019
  11. #11
  12. drummer79
    Froyo Nov 23, 2019
  13. #13
  14. drummer79
    Froyo Nov 23, 2019
    No way! It's just that easy Hugh!? Well lemme see.
  15. #15
    Swejuggalo likes this.
  16. #16
