Please help me
  1. 22joshgeorge22
    Donut Oct 29, 2014
    22joshgeorge22 , Oct 29, 2014 :
    My one plus one was working fine and for some reason i got a notification. One of those pop ups that says "lock screen not working" and it wouldn't go away. I had two options "report" and "okay" when i hit "okay it would go away for like a 1/10th of a second and then reappear. I tried entering the recovery and factory reseting. thinking that it would perhaps fix the problem with the lock screen. But it didn't. For some reason now whenever I try to turn on my Phone it goes to the Oneplus boot screen and doesn't go any further. What should I do next?
  2. domi39
    KitKat Oct 29, 2014
    domi39 , Oct 29, 2014 :
    its a software problem CM is working as fast as they can to fix it
    gusuraman likes this.
  3. rgb1998
    KitKat Oct 29, 2014
    rgb1998 , Oct 29, 2014 :
    If you can get into recovery clear cache and dalvik cache. If running custom ROM that isn't CM11S, reflash that ROM in recovery but only delete cache and dalvik. So you won't lose any personal data.
  4. mossy1963
    Jelly Bean Oct 29, 2014
  5. malidan
    Nougat Oct 29, 2014
    malidan , Oct 29, 2014 :
    Dude, i binned that junk os long time ago, i would suggest you do the same. There has been so much tinkering to mask the shortfalls of the device the os has become unstable. Installing another OS will also help you find out if it is software or a hardware, memory, issue.
  6. 22joshgeorge22
    Donut Oct 29, 2014
    Thank you for the Idea but it did not work... any more ideas?
  7. rgb1998
    KitKat Oct 29, 2014
  8. 22joshgeorge22
    Donut Oct 29, 2014
  9. VanessaRican
    Gingerbread Oct 29, 2014
    VanessaRican , Oct 29, 2014 :
    A friend of mine has the phone - why he couldn't send me an invite?? He get's no invites to send to others..??
  10. 22joshgeorge22
    Donut Oct 29, 2014
    How long has it been since he got his Phone it can take a while to receive the invites.
  11. mossy1963
    mossy1963 , Oct 29, 2014 :
    I have provide a link to the definitive and official OnePlus patch fix to bootloop problems above, It is also in my signature link
  12. VanessaRican
    He got the phone two weeks ago - I think it's a long time ago?
  13. 22joshgeorge22
    Donut Oct 29, 2014
  14. rgb1998
    KitKat Oct 29, 2014
    Wow! A 16 GB model? Those are very rare.
  15. 22joshgeorge22
    Donut Oct 29, 2014
    Yea. Do you know if there is a way to completely get rid of the OS and then re install it or is that just not a thing?
  16. rgb1998
    KitKat Oct 29, 2014
    Using fastboot that is certainly a possibility. If you download the cm 11s ROM and then go to recovery and get rid of the system then reinstall the cm 11s ROM. In this method fastboot is unneeded. Do you have a USB otg cable that could plug into external storage?
  17. firewire2035
    KitKat Oct 29, 2014
    firewire2035 , Oct 29, 2014 :
    not a good idea, you may have a physical memory limitation. OS probably has hard coded memory size.
  18. 22joshgeorge22
    Donut Oct 29, 2014
    that's not good but thank you for the input.
    does anyone know what i should do? This is becoming very frustrating and I have school it's really awkward when i look down at my phone just to check the time and the screen is black. haha
