PLEASE HELP. OPO freezes in Cynogen Boot Animation after Flashing TWrp recovery!
  1. Alex276
    Froyo May 17, 2015
    Alex276 , May 17, 2015 :
    Hi guys im happy with my OPO since 9 months now but i decided to now get root access and flash it ..... the problem is i watched this Tutorial
    and everything worked fine but after i flashed the custom recovery like he said in min 7:34 my phone get stuck everytime i restart it and freezes in the new cynogen animation for hours and i cant go on :/ im really not experienced and looked for hours in forums many have common issues but not exactly the same and i didnt find a solution please help me i dont know what to do.
  2. jirojo2
    Gingerbread May 17, 2015
  3. DaxNagtegaal
    Marshmallow May 17, 2015
    The1Lion, azp3, Antoine Vdb and 2 others like this.
  4. jirojo2
    jirojo2 , May 17, 2015 :
    @DaxNagtegaal Hi! Thanks for your help with touchscreen yesterday, unfortunately, the firmware fix did not work for me. But thanks, really ^^
    DaxNagtegaal likes this.
  5. DaxNagtegaal
    DaxNagtegaal , May 17, 2015 :
    That's sad, sorry that it didn't work for you
    jirojo2 likes this.
  6. Alex276
    Froyo May 17, 2015
    i dont really need another 10 guides to root my phone the one i have is difficult enough for a noob i just really want my phone to boot normal and not get stuck everytime can you pls tell me how i solve this problem or what i did wrong i tried everything
  7. DaxNagtegaal
    stop complaining and follow my guide
    The1Lion and Jeffrey98 like this.
  8. Jeffreyvdv3lde
    Jelly Bean May 17, 2015
    Jeffreyvdv3lde , May 17, 2015 :
    You know that he is trying to help you. If you can do it better, try it yourself. But don't come here if your phone is bricked or something else is wrong with it. Have fun with flashing :)
  9. Alex276
    Froyo May 17, 2015
    im not complaining im just scared cause i dont want my phone to get broken if i cant get it right i atleast want it normal i never done this before and its very confusing but thanks for you advice ill try it i hope it'll work even my phone is not working correctly
  10. Jeffreyvdv3lde
    They just don't get it, and I really don't know why people are still using toolkits. But, nvm they never listen.
  11. DaxNagtegaal
    your phone is not broken, don't worry, you're just panicking for no reason.
  12. Alex276
    Froyo May 17, 2015
    okay good but i have one problem after the other .... so i just downloaded your program/guide
    i watched the video first step: go in fastboot mode and click unlock bootloader the warning appears like in the vid and then nothing happens at all on my phone ... is it because i already unlocked the bootloader or am i again to stupid to do something?
  13. Jeffreyvdv3lde
    And, so if we look to this story, we can say that it is a flasher without any knowledge about it. Conclusion: Never start flashing if you don't know what you can do to your phone.
  14. Jeffreyvdv3lde
    If your bootloader is already unlocked you can go to the next step.
  15. Alex276
    Froyo May 17, 2015
    hey thanks for your help and yes i dont have any knowledge with android phones thats why its my first time and thats why i need guides to get it but the problem is not my lack of knowledge if i do anything exactly like in the guide the problem is that something istn just working suddenly but if you have the knowledge please tell my why my phone gets stuck in cynogen animation after flashing the recovery
  16. Alex276
    Froyo May 17, 2015
    thanks thats helpfull
  17. Jeffreyvdv3lde
    It may has damaged the system partition, and because of that the system can't boot anymore. If you boot into TWRP you can do a full system wipe (Advanced wipe, data, system, cache and dalvik cache) and install the CyanogenOS 12 zip. And you can also give OxygenOS a try if you like stock Android.
  18. SayMyName
    SayMyName , May 17, 2015 :
    I like how guys start using chick avatars to get help. I should try that some time.
    DeltaSky likes this.
  19. Alex276
    Froyo May 17, 2015
    okay so i went to next step go in fastboot mode choose twrp recovery and flashed it ... the cmd console appeares but there is just "the command "fastboot" is written wrong or couldnt be found" ... great i dont get it what im doing wrong .. is it maybe cause i saved something wrong? maybe i have to install this programm at this place where i have the sdk files ?
  20. The1Lion
    The1Lion , May 17, 2015 :
    I followed the guide, my OPO has twrp recovery and is rooted. Step by step written instructions.
    DaxNagtegaal and theshinybeast like this.
