PLEASE HELP. OPO freezes in Cynogen Boot Animation after Flashing TWrp recovery!
  1. Jeffreyvdv3lde
    Jelly Bean May 17, 2015
    Jeffreyvdv3lde , May 17, 2015 :
    You do have the slimmed SDK files, the needed fastboot drivers and what do you type? The command should look like "fastboot flash recovery recovery.img" and the recovery needs to be inside of the slimmed SDK package and you need to open the CMD inside the slimmed SDK.
  2. Alex276
    Froyo May 17, 2015
    Alex276 , May 17, 2015 :
    thanks for your help but now i think my OPO sucks.. i got in the recovery advanced wipe but NOO wipe failed and my phone still doesnt work .. i love it haha please help me youre my only chance haha
  3. Alex276
    Froyo May 17, 2015
    yes i did that all correctly but it just failed and now i have the problem with the oneplus one toolbox that it dowstn work
  4. Jeffreyvdv3lde
  5. Jeffreyvdv3lde
  6. Alex276
    Froyo May 17, 2015
    okay now i could flash it with the toolbox but have the same problem i got to twrp recovery try to restart but still get stuck great .... and yes i tried the advanced wipe in twrp but it failed i dont know what to do this is my only real problem
  7. Jeffreyvdv3lde
    It seems like your system partition is damaged. Don't know what the hell you did, but you should give this toolkit a try: https://forums.oneplus.net/threads/...ol-restore-stock-cm11s-fix-bricks-etc.237827/ it will bring your phone back to 44S. But, this is something you do at your own risk. If you point a finger at me for messing up your device I'll laugh in your face. @DaxNagtegaal, or do you have a other solution. And by the way, you first need to install the drivers, then connect your phone to your pc by shutting off your device and keep holding ONLY volume up when connecting your device, it'll get into BULK mode.
  8. Alex276
    Froyo May 17, 2015
    hm okay thanks i just did a complete wipe now and now it works again do i have to do everything again? or is it still bootloader unlocked and a different recovery? i give it a look
  9. macem29
    macem29 , May 17, 2015 :
    that tool is a last resort really for completely unresponsive bricked devices
    it also involves installing more drivers, best to not go that road unless you have to
    go back to Dax's guides, there's one that tells you precisely what to do if you have
    TWRP but no ROM
    DaxNagtegaal likes this.
  10. Jeffreyvdv3lde
    What do you mean? Is the device booted into 44S or did the wipe inside TWRP worked?
  11. Jeffreyvdv3lde
    Yes, but the problem is that she can't wipe, atleast in the beginning. I can't help her with that, probably a damaged system partition.
  12. headphones1
    headphones1 , May 17, 2015 :
    Actually, an old version of twrp did the same for me. Make sure they have the latest version (v2.8.6.0) from here.
  13. Alex276
    Froyo May 17, 2015
    i just put it on the factory settings in twrp and now it worked i just have to root now i guess
  14. Jeffreyvdv3lde
    You don't need root, only if you wanted to root your device. Did you install a OS?
    macem29 likes this.
  15. macem29
    I'd focus on getting an OS on the device first....root you can do later
    without data loss, use TWRP to flash a ROM and get the thing back to life
  16. Alex276
    Froyo May 17, 2015
    yes i wanted to root and uhm the OS is the CM12 i guess
  17. Jeffreyvdv3lde
    If you did a factory reset you need to install CyanogenOS 12 again. Which version of TWRP do you run? Please send this info asap, I am going to eat in a few minutes.
  18. Alex276
    Froyo May 17, 2015
    im have the newest version of twrp but i think now verything works it was really easy the big problem was just something was wrong with my partition but after a factory reset everything works fine ^__^
    i thank you a lot for your help really appreciate it and have a good lunch :D
    #38
  19. Jeffreyvdv3lde
    Thnx :), have a nice evening!
    Edit: It is 6:25PM at my house
    #39
