please hurry up with the OnePlus 3T battery fix
  1. Rodo20 Froyo Dec 7, 2017
    G_Bédouin_Axel_vZuV likes this.
  2. Rodo20 Froyo Dec 7, 2017
    Hydra Bob likes this.
  3. darius1988 KitKat Dec 7, 2017
  4. G_Bédouin_Axel_vZuV Froyo Dec 7, 2017
  5. KENELM Cupcake Dec 7, 2017
  6. darius1988 KitKat Dec 7, 2017
    darius1988, Dec 7, 2017 :
    Don't said that untill you have done it... I have Oreo from the first beta and I don't have issues or battery drain , why? because I made a factory reset before and after update , and it's not only me ( all that have done a clean install have only minor issues).
    Few days ago I helped someone who wants downgrade to Nougat but I recomend him factory reset before and keep the first 3-4 charges beetwen 5-100% and now all works good , it is Happy with battery. When you move from a major update to other you should perform a factory reset.
    Hydra Bob, Punk_69 and uz4ever like this.
  7. G_Bédouin_Axel_vZuV Froyo Dec 7, 2017
    G_Bédouin_Axel_vZuV, Dec 7, 2017 :
    I'm serious, this is a bug, and OnePlus withdrawn this update because of it.
    I wipe the cache of my OnePlus 3T since day one, I know this trick. I also made a factory reset after this update. But, it didn't change anything. It's a bug...that doesn't affect every one because it depends on your area and on your operator.
    So, this is great to give advice, but I can assure you there is no workaround at the moment.
  8. MTD.TYK Donut Dec 7, 2017
    Pxblx likes this.
  9. Rodo20 Froyo Dec 8, 2017
  10. sandy_cm Gingerbread Dec 8, 2017
  11. vinay_thakur16 Cupcake Dec 8, 2017
