PLS HELP ME
  1. Mahir_Emam
    Cupcake Aug 16, 2019
    Mahir_Emam , Aug 16, 2019 :
    my network bar is empty for both Sim cards and it says no service. though they work good in other phones. And whenever I try to make a cellular call it shows "turn off airplane mode to make a call" though it's turned off. I'm suffering for the last 8 months, someone told me that wait for future updates it shall be okay but didn't work. PS: my warranty is over and I hard reset my phone several times. as an eSport player I have to play so many tournaments with the cellular network so pls help meee OP community [e]1f62d[/e]
  2. B_Wrath
    Marshmallow Aug 16, 2019
    B_Wrath , Aug 16, 2019 :
    In all this, did you try taking it to the service center and getting it checked?
    And what happens if you use another sim in your phone?
  3. Mahir_Emam
    same problem shows up and I didn't try to take it to service center because my warranty is over.
  4. B_Wrath
    You had the issue for 8 months! That was within warranty period! Who told you to wait!?
    Now take it to the service center and get it checked.
    Also, you can try clean flashing the latest build before you take it to the service center.
  5. Mahir_Emam
    I shifted from hydrogen to oxygen recently but didn't work. thinking it might be a software problem (rom bug ) so didn't want to go to service center plus I live in Bangladesh and there is no official OnePlus servicing center. my brother bought this phone from China .
  6. B_Wrath
    In Bangladesh, did you get the signal earlier or is this a problem since the beginning?
    buntycubal and Starcommander like this.
  7. Mahir_Emam
    yea I had been using both the Sim card properly . after network reset this problem started
  8. B_Wrath
    Then ask the sim providers to give you the correct apn. Why did you do a network reset?
    Raresch, buntycubal and Starcommander like this.
  9. SoniaB
    Nougat Senior Moderator Aug 16, 2019
    SoniaB , Aug 16, 2019 :
    what network providers are you using. Have you checked to make sure APN settings are correct?
  10. Mahir_Emam
    Cupcake Aug 22, 2019
    Mahir_Emam , Aug 22, 2019 :
    my radio power is turned off everything is ok except this
  11. Blue-agila
    Ice Cream Sandwich Aug 22, 2019
  12. Mahir_Emam
    that has got nothing to do with my problem
  13. Blue-agila
    Blue-agila , Aug 22, 2019 :
    It has if Airtel only have 4G in your area
    otto2 likes this.
  14. Mahir_Emam
    if I try to select 4g it automatically goes back to 2/3g
  15. Blue-agila
    In your phone dialer
    *#*#4636#*#*
    Phone information
    What does it say under prefered network type
    It should say something like
    LTE/CDMA/UMTS
  16. Mahir_Emam
    Cupcake Aug 25, 2019
    Mahir_Emam , Aug 25, 2019 :
    Blue-agila likes this.
  17. Blue-agila
    Ice Cream Sandwich Aug 25, 2019
  18. Mahir_Emam
    I did, didn't work
  19. Blue-agila
  20. Mahir_Emam
