Plugged in can't charge right now (but charging) via OnePlus 8T
  1. JovaniGA
    Cupcake Jun 21, 2021
    JovaniGA , via OnePlus 8T , Jun 21, 2021 :
    Hello there,
    I bought my 1+8T 3 moths ago, first weeks everything was normal and fast charging was amazing, after that, i started to have problems with fast charge because it shows this *screenshots*
    as you can see, on lock screen shows 30 minutes aprox. to full charge, but on settings shows that messages that makes me be worried about it because I have fast charge until 50% battery , after that it comes too slow charging.
    If I disconnect the charger and connect aging it shows fast charge on settings too and start to have fast charging.
    Do you have some idea about what could be happening, is it my charge port which is damaged, or its my charger?
    Gor.V likes this.
  2. #2
    Gor.V likes this.
  3. Cicala
    Gingerbread Jun 21, 2021
  4. Gor.V
    KitKat Jun 21, 2021
    Gor.V , Jun 21, 2021 :
    Hey there.
    It could be a wall socket issue that's causing the fluctuation. Did you try a different plugin socket that has stable power supply to see if the issue still exists?
  5. #5
    JovaniGA likes this.
  6. A.Saketh Gupta
    Ice Cream Sandwich Jun 21, 2021
  7. Dresa91
    User of the Year 2016; Most Active User 2020 Jun 21, 2021
    Dresa91 , Jun 21, 2021 :
    What happens when you turn of optimized charging?
    Cicala likes this.
  8. JovaniGA
  9. JovaniGA
    I test it on many places out of my home, and it's the same. Always the same. Something when a disconnect and connect again, it star to charge really fast.
    above 50% if I disconnect and connect aging it charges like warp charge
    Gor.V likes this.
  10. JovaniGA
  11. JovaniGA
    I have been testing my charge without that option for a few weeks and it doesn't change anything, so same problem.
  12. Dresa91
    Then please visit a service center or contact support via www.oneplus.com
    They can check your phone
  13. JovaniGA
  14. Dresa91
    Can you test it with another OnePlus charger and cable?
  15. JovaniGA
  16. Dresa91
  17. Cicala
    Cicala , via OnePlus 8 T-Mobile , Jun 21, 2021 :
    Whoa, how are you charging your device? Your response is a good sign.
    Visit the 1+ store for all your needs! When signing into the 1+ app store. You'll get discounts for your purchase. All prices are reasonable, with a decent delivery time.
    Wishes you the best with your device!
  18. Gor.V
    KitKat Jun 22, 2021
    Gor.V , Jun 22, 2021 :
    Then there's a possibility of an adapter and/or cable malfunction. Hoping it's not gonna be a phone issue :expressionless:.
