#PMChallenge Open an application on the buttons Long/Double tap
  1. yoanpg Cupcake Feb 17, 2019
    yoanpg, Feb 17, 2019 :
    Who are the user
    Everyone
    What is the proposed function?
    The current parameter allows to select an preset action on the long tap and double tap of the sensitive buttons at the bottom of the phone. It should be good to also give the possibility to select an application to allows the user to easily and quickly open an application (like it is already possible to do with the gestures)
    What is the user value?
    Save time to open a often-used application, from any screen
    If there are existing comparable functions in the smartphone industry, how is your proposed feature superior?
    I haven't seen that in others phone
