4
Pocket mode in OnePlus 7 Pro
  1. G_Hugo_Meneses_rOcc
    Donut Jun 28, 2019
    G_Hugo_Meneses_rOcc , Jun 28, 2019 :
    When I'm walking with my phone in my pocket, it keeps turning the screen on and generating fake clicks (music taco change, pause, camera opening).
    Is Pocket mode implemented or to be implemented?
  2. D1561693125642
    Cupcake Jun 28, 2019
    D1561693125642 , Jun 28, 2019 :
    I have the same problem. It happens so often that I have to turn double tap to wake off. I hope there will be a fix soon because I really like this feature.
    prd068 likes this.
  3. mjdb71
    Gingerbread Jun 28, 2019
    mjdb71 , Jun 28, 2019 :
    I had the same it seems. After 45 min walk with OP7 pro in my back jeans pocket it had factory wiped itself. I removed the phone from pocket and I saw the blue Android setup page asking me the language to select. So terrible. I had exactly the same 1 year ago with me OP6T. I solved this by turning on pocket mode. But pocket mode is gone, unacceptable. If this happens again then I return the OP7 Pro. When do we get pocket mode back and if not, what can I do to prevent this happens again?
    prd068 likes this.
  4. Logancd1
    Ice Cream Sandwich Jun 28, 2019
    Logancd1 , Jun 28, 2019 :
    No pocket mode possibility on OnePlus 7 Pro. There isn't a proximity sensor.
    prd068 and samithahm like this.
  5. samithahm
    Froyo Jul 2, 2019
    samithahm , Jul 2, 2019 :
    it's in-display, just like the fingerprint.
  6. spot01
    Jelly Bean Jul 2, 2019
    spot01 , Jul 2, 2019 :
    Security and lock screen - smart lock
    Turn off on body detection
  7. mjdb71
    Gingerbread Jul 2, 2019
    mjdb71 , Jul 2, 2019 :
    It was turned off on my phone. Do you suggest to turn it on, so the phone is always unlocked while walking?
  8. Logancd1
    Ice Cream Sandwich Jul 2, 2019
    Logancd1 , Jul 2, 2019 :
    No, there is no proximity sensor in the phone at all.
  9. samithahm
    Froyo Jul 2, 2019
    So how come the screen goes off when you place the phone on your ear while on call?
  10. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Jul 2, 2019
    KeepTransisting , Jul 2, 2019 :
    It uses the ambient light sensor. I less optimal solution
  11. samithahm
    Froyo Jul 2, 2019
    can't they use that for the pocket mode? it seems practical.
  12. KeepTransisting
    In a way, they probably could. But it wouldn't be very ideal due to the fact that pocket mode would randomly kick on when shifting into low light. I'm hoping they're working on it, maybe a combination of the gyroscope and ambient light sensor, but who knows.
    samithahm likes this.
  13. Logancd1
    That's used exclusively for calls as far as I'm aware. If this were used for pocket mode, and you wanted to use your phone in a very dark room, you wouldn't be able to because pocket mode would be active. The ambient light sensor would sense no light and you'd be unable to use your phone.
  14. KeepTransisting
    Yep. In theory, it could be used with the gyroscope in a limited fashion. For example, when most people put their phone in their pocket, they put the phone in upside down. So the gyroscope detecting a 180 degree inversion along with the ambient light sensor detecting darkness could work, but it wouldn't be perfect.
  15. samithahm
    Froyo Jul 2, 2019
    So your saying when I answer calls in the dark the screen goes off?
  16. samithahm
    Froyo Jul 2, 2019
    Agreed! But without pocket mode it's really irritating you know!
  17. Logancd1
    I'm saying that presently, when a call is on the screen and the ambient light sensor senses no light, it deactivates the screen.
    If we were to introduce this feature not just when a call is active and on the screen, pocket mode (or whatever they'd call it) would be activated in dark rooms, causing you to be unable to use your phone.
  18. KeepTransisting
    No, because there's not enough of a change in the light level. In fact, I'd be worried about the screen staying on when pressed to your face if you answer in the dark.
    Logancd1 and samithahm like this.
  19. Logancd1
    It's possible but I feel like there are too many variables. What if the person is sitting down? It won't be facing down like that, so that situation would no longer apply. And if you want to present the option of adding the 90 degree turn, what if I want to use my phone in landscape in a dark room?
  20. samithahm
    Froyo Jul 2, 2019
    Yeah I get it. Thanks fellas. But if they could find a way to bring back Pocket mode or something similar, that would be so great and helpful and would keep OnePlus at the top for me as always!
